Old 2nd January 2017, 07:53 PM
I replaced auto-dimming mirrors on my S8 on purpose. I find the plastic surround really annoying as it robs some field of view, and it looks cheap with the aluminium mirror housings.
I replaced them with much cheaper A8 heated mirrors, flat. They fit just fine and look very nice with the aluminium housings. Even though they are flat I have no problem with field of view. I'll take a pic.
Old 10th January 2017, 03:37 PM
Spanker's Avatar
Spanker Spanker is offline
My replacement mirror came today from California. It appears to be new "old stock" which is good, and no duties to pay either.
So up to now I am happy.
I am not sure if it is the same tint as the existing good mirror on the car but it looks tintless at the moment and I am hoping it will be a green tint when it needs to do it's stuff when the knob behind forgets to dim his (or her!) high-beam.
But here's the bit I feel stupid about asking......
How do you replace the mirror glass?
It looks as though it should just clip-off / clip-on. And I suspect that is exactly how it is done.
But with me being a clumsy oaf prone to damaging the paintwork, and these mirrors being relatively rare, I would appreciate someone giving me the heads up on what to do.
Plastic pry tool?
Tilt the mirror outwards/upwards, inwards, downwards and apply pressure to the ....???
I would normally try to work it out myself but I know that someone will have done it before and will be able to offer some great advice.
TIA
Dean
Dean
Old 10th January 2017, 04:24 PM
Yes they just pry off, don't do it when they are cold as the plastic can be brittle.
If you have to do it in winter warm the whole assembly up with a hairdryer for several minutes first.
IIRC you adjust the mirror to the extreme position and then lever it off carefully with a WIDE plastic tool.
In or out can't remember but try both and it will be obvious which gives better access, if I had to guess I'd say in and down a bit and lever off from the outside.
You'll probably hear one of the catches pop loudly off first which can be a bit disturbing then the rest follow easily. I think I last used a plastic ice scraper.
Old 10th January 2017, 07:08 PM
Spanker's Avatar
Thanks Andrew
I shall put this on tomorrow when the sun is up and I have my Black & Decker heat gun in hand (on it's lowest setting).
I would never have thought about the fact that prying plastic in low temperatures risks snapping of important plastic lugs. I can warm my hands up at the same time
Dean
