Old 13th January 2017, 06:54 PM
Great stuff mate, thanks
Looks pretty straight forward even if I'm not the biggest fan of soldering ribbons.
Old 13th January 2017, 07:32 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Lcd displays can be done with a steady hand.
Dis needs a hot air soldering station to be done with any degree of success
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
I'm failing miserably to find any supplier selling replacement screens.
Good thing that clusters can be bought from abroad from as low as £30, but you all guys are saying that this pixel issue shows up after some time of driving so even if s listing has a picture of plugged in and working cluster what guarantee is there that they are in full working order long term/drives.
Old 13th January 2017, 08:04 PM
BBA-Reman down in Rochester can repair dashboards with pixel issues, remove the dash and send it to them and they can normally turn it around in 2-3 days
Details here -
https://www.bba-reman.com/gb/catalog...ledproduct=284
Old 13th January 2017, 08:07 PM
Yeah, I'm well aware of them and other guys, but the issue here is the milage and clock screens (two little ones), and can't find replacements for sale.
Old 13th January 2017, 08:08 PM
Neil, can they do facelift D2s?
I've seen several people offering that service for the lower-resolution PF versions, but not the FL versions.
I really need mine doing, not due to pixels but being blank when cold.
Old 13th January 2017, 08:10 PM
Yes the small 2 screens are the ones that tend to go, it's exactly what they do they fix the damaged ones whichever ones are causing the issue
Yes I'm pretty sure they can Andrew but give them a call for peace of mind
Old 13th January 2017, 08:32 PM
Ah ok, that's great then. It could be a much better solution for you guys if price is right especially if they fit new ones unless it's down to one faulty components not the actual screens which made me think now that this could be the actual cause and not the screens.
Old 13th January 2017, 08:40 PM
It used to be £180 for a cluster repair there a few years ago so maybe a little more now, but would be interested to know
Old 13th January 2017, 09:06 PM
Yeah, it would be good to know. I can see why it cost so much. They are not silly, they know the cost involved in changing the cluster on D2s and hassle hence the price. Especially that Dis screen is cheap.
If it's only two little screens I would expect it to be lower as I am almost convinced that this fault is down more to a transistor not the actual displays.
And if that's what it is than a diy solder job on component like that is very easy.
Cost would be minima as well, time it takes not long either and don't need to send it away.
Could possibly enquire about it and see if they will share some light on this issue and confirm the fix ... but whoever enquiries about can't sound like they know what they are talking about
