Old 24th January 2017, 07:48 PM
Kurmax Kurmax is offline
Default Headlights change
Hi all,
I own a A8 D3 4.2 TDI and my headlights are quite weak.
I was thinking of changing them to LED ones.
Any comments or hints?
Thanks
Kurmax
_____________
Audi A8 4.2 TDI 2006
Old 24th January 2017, 11:24 PM
H-M3 H-M3 is offline
hi and welcome. Does your one have xenons? if so could be bulbs fairly old also the lens discolour on the headlight so needs polishing.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 26th January 2017, 04:29 PM
Johnmed's Avatar
Johnmed Johnmed is offline
I've pondered LED lamps now they seem quite reliable and not to emit so much heat etc, and it's dark most of the time. Has anyone had success with them on the D3?
2007 Mini Cooper S R56
Old 26th January 2017, 09:34 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I would want go led.
You won't get the same light.
If you got xenons and it's dull you git 3 factors mainly.
Bulb, lens and reflector.
Bulbs age and lose their illumination over time, so a decent set of genuine bulbs is a good place to start as well as s lens polish
If still poop, then you can look at reflector refresh it refresh the whole lot with a morimoto D2s unit.
I'm going to do Mine at the end of the summer.
[center]
06 3.0TDI Quattro:
Options:
Old 26th January 2017, 10:07 PM
Over time the HID bulbs slowly consume their electrodes. They self adjust for this but can only go so far. I'm guessing a new pair of genuine (not knock offs) will go a long way to restore them. Failing that, explore the alternatives Scott came up with.
Mine are no where near as bright as when I bought it over 6 years and 60k miles ago. I'm getting new bulbs
Old 27th January 2017, 09:05 AM
I had to restore the lights in the A4 because the reflector in the projector was scorched from the heat off the halogen. So the A4 now has a full conversion, side, dipped, main, fog, indicators) to LED (few pics below). The dipped beam LED's are quoted at 9000 lumens pair. Their actual output is better than halogen but below a good set of OEM Xenon's.
I have thought about retro fitting the D3 but the bulb monitoring of the central electronics module would be throwing all sorts of warnings - of which is an MOT failure - this brings me back to a project I have sitting in waiting. Also, the LED aftermarket tech isn't up to the standard to be better then OEM Xenons yet. So as others have said, get a new set of Xenons.
ID:	15472   Click image for larger version
ID:	15473   Click image for larger version
ID:	15474   Click image for larger version
ID:	15475   Click image for larger version
ID:	15476   Click image for larger version
ID:	15477   Click image for larger version
Matt
Old 27th January 2017, 09:29 AM
ScottD3's Avatar
If you want headlight work, drop me a PM.
We can rechrome the reflectors, supply Philips and Osram bulbs (genuine), uprate the reflectors to Morimoto and supply LEDs (not for main beam).
Morimoto units don't affect the bulb warning system as we use standard ballasts.
We are working on a set of Morimoto lights that work with the AFS system.
Due to the housing and motors of the AFS system, its pretty tight in there to fit any uprated bits but we are getting there.
We are also working on new LED bulbs the front and rear lights, along with a couple of little extras for both lights.
[center]
06 3.0TDI Quattro:
Options:
Old 29th January 2017, 08:50 AM
Turbo Tony's Avatar
Have you seen these LEDs?
http://deautokey.com/product/new-d1s...en-audi-models
Storytellers Villa Orlando
2008 Audi S8
Old 29th January 2017, 04:13 PM
With prices to match the real thing
Old 29th January 2017, 04:40 PM
ScottD3's Avatar
I get Morimoto D2s bulbs with 2 year warranty for £60 + postage.
Just saying
[center]
06 3.0TDI Quattro:
Options:
Tags
headlights change
