Old 31st January 2017, 12:07 PM
Jon_viola Jon_viola is offline
Default 1st VCDS Scan- What does it all mean?!
Hi just done a full scan for the first time. What does it all mean and do I need to do anything?
I notice its throwing up a fault code re the EGR which has been mapped out. Can I change the config to lose this?
Tuesday,31,January,2017,13:07:06:45075
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
VCDS Version: 17.1.2.0 (x64)
Data version: 20170127 DS267.1
www.Ross-Tech.com
VIN: WAUZZZ4E77N017525 License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 18 19 1D 1E 34
36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77
VIN: WAUZZZ4E77N017525 Mileage: 283630km-176239miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: Cannot be reached 1100
31-Engine other -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: Malfunction 1110
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E1 910 409 B HW: 4E1 907 409 A
Component: 4.2L V8TDI G000AGMª0010
Revision: --H04--- Serial number: AUX3Z0G1316673
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 2345C323E265EB59DE-8076
No fault code found.
Readiness: 0 0 1 X 1
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 S HW: 09E 927 156 B
Component: AG6 09E 4,2 TDI RdW 0010
Revision: --H01--- Serial number: 0102515
Coding: 0000001
VCID: 3365336352857BD92E-8066
2 Faults Found:
049408 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 281776 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:14
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 57.0°C
T.B. Angle: 60.0°
006273 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 281776 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:14
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 224BC627FD7FE251D5-8076
2 Faults Found:
02083 - Message for Delay Request
004 - No Signal/Communication - Intermittent
01314 - Engine Control Module
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0G1316673
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58BFA4CFEBA37881FB-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
2 Faults Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 0
Reset counter: 18
Mileage: 281824 km
Time Indication: 0
Date: 2017.01.09
Time: 10:25:10
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 18
Mileage: 281824 km
Time Indication: 0
Date: 2017.01.09
Time: 10:25:10
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
VCID: 2447C03FE76BEC61A7-8070
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300BC077579000
Coding: 0000002
Shop #: WSC 00000 785 00200
VCID: 3A7B1E4775EF8A91ED-806E
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000031782
Subsystem 3 - Serial number: 0122.02.070000000100010002ÿ
Subsystem 4 - Serial number: 010002ÿ
1 Fault Found:
02244 - Button in Control Head is Stuck
000 - - - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Mileage: 282072 km
Time Indication: 0
Date: 2017.01.13
Time: 09:19:53
Freeze Frame:
Bin. Bits: 01000000
Bin. Bits: 0000000
Bin. Bits: 001
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000115342
Coding: 0022625
VCID: 1C37F8DFDF1BD4A11F-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0143121
VCID: 36630A7741F76EF109-8062
Subsystem 1 - Part No: 4E2 910 113 C
Component: Wischer WWS D3 H60 0440
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 283066 km
Time Indication: 0
Date: 2017.01.24
Time: 17:19:46
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBG3169617
Shop #: WSC 00000 000 00000
VCID: 1A3BFEC7D52FAA910D-804E
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276U8200307
Coding: 0000001
Address 11: Engine II Labels: Redir Fail!
Component: 4.2L V8TDI G000AGSª0010
Coding: 0011773
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H14 4210
Revision: 91H14421 Serial number: 0037P0G08VUY
Coding: 0431707
VCID: 275DD733965D077982-8072
Subsystem 1 - Serial number: 63328RB40212C3097
Subsystem 2 - Serial number: 63428RB40212BAC8P
Subsystem 3 - Serial number: 63528RB40212986FN
Subsystem 4 - Serial number: 63628RB402129BDFY
Subsystem 5 - Serial number: 63729RB4021BB850L
Subsystem 6 - Serial number: 63829RB4021BB820J
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0112141
VCID: 65C19D3BACD1D56970-8030
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 B HW: 4E0 920 951 B
Component: KOMBIINSTR. VDO H82 0530
Revision: D05 Serial number: AUDID3G2000909
Coding: 0048413
Shop #: WSC 00508 067 57207
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 70498 km
Time Indication: 0
Date: 2010.06.15
Time: 08:56:29
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 G
Component: Heizgeraet H08 0140
Revision: 0000000C Serial number: 00000009013887
Coding: 0000001
1 Fault Found:
00664 - Fuel gauge
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B072258011
Coding: F5DDDFFF707E1E
VCID: 6CD7E81F4F3BE4212F-8038
2 Faults Found:
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 36
Mileage: 281776 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:14
01342 - Engine Control Module 2 (Slave 1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 36
Mileage: 281776 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:14
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 A HW: 4E2 905 218 B
Component: FPI_1 H01 0020
Revision: 01000102 Serial number: 29012007145348
VCID: 1F4DCFD3CE0DCFB9FA-804A
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 14
Reset counter: 47
Mileage: 283632 km
Time Indication: 0
Date: 2017.01.31
Time: 12:57:02
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 010000
VCID: 2B552B034AB5231966-807E
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
Shop #: WSC 30026 002 1048576
VCID: 2A5B2E07854F3A119D-807E
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 36
Mileage: 281776 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:14
01400 - Suspension Level Control
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 36
Mileage: 281776 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:14
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063342
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 T HW: 4E0 919 887 L
Component: MNS ECE H48 1030
Revision: 00000000 Serial number: 364CZ077643875
Shop #: WSC 00751 210 83996
VCID: 3E73125769C7A6B1D1-806A
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000700900065
Coding: 0036048
VCID: 1D31F5DBC401DDA9E8-8048
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 16
Mileage: 262136 km
Time Indication: 0
Date: 2017.01.09
Time: 10:24:00
Freeze Frame:
Bin. Bits: 00000000
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 D
Component: Türsteuer.FS BRM005 0180
Coding: 0032622
VCID: 204FCC2FF373F041C3-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 C HW: 4E0 907 289 C
Component: Komfortgeraet H09 0020
Revision: 00200009 Serial number: W040702220086
Coding: 0004861
VCID: 2959D10B8049310994-807C
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 36
Mileage: 281776 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:15
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000005099
Coding: 0000023
VCID: 2C57281F8FBB24216F-8078
1 Fault Found:
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 37
Mileage: 282788 km
Time Indication: 0
Date: 2017.01.23
Time: 13:28:44
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000106069
Coding: 0010101
VCID: 1E33F2D7C907C6B1F1-804A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 37
Mileage: 262136 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 D
Component: Türsteuer.BF BRM005 0180
Coding: 0032622
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0001031
Shop #: WSC 56998 001 1048576
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 36
Mileage: 281776 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:14
Freeze Frame:
Voltage: 11.08 V
Count: 241
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000018
Shop #: WSC 23123 823 51872
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 37
Mileage: 281784 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:14
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396CY077560862
Coding: 0000001
VCID: 3169396BA89949C95C-8064
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 E HW: 4E0 919 148
Component: R0078 TVhybridT 0470
Revision: R0H06000 Serial number: 76300800253501
Coding: 0000003
VCID: 2541DD3BEC511569B0-8070
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000002113
Shop #: WSC 00586 586 91374
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2702230006
Coding: 344530393135313035412056413032373032323330303036
Shop #: WSC 00000 128 00289
3 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 280180 km
Time Indication: 0
Date: 2016.12.01
Time: 05:15:13
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 280180 km
Time Indication: 0
Date: 2016.12.01
Time: 05:15:13
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 37
Mileage: 281776 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:14
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032622
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000700049983
Coding: 0202127
Shop #: WSC 65762 132 00001
3 Faults Found:
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 2
Reset counter: 37
Mileage: 281776 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:24
Freeze Frame:
(no units): 0.0
Voltage: 0.00 V
(no units): 27.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 37
Mileage: 281776 km
Time Indication: 0
Date: 2017.01.07
Time: 11:54:24
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 158
Mileage: 278711 km
Time Indication: 0
Date: 2016.11.03
Time: 17:28:19
Freeze Frame:
(no units): 98.0
Temperature: 9.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000702230220
Shop #: WSC 12336 024 394758
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7210C8
Coding: 1020402
VCID: 5CB7B8DF9F9B94A1DF-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032622
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08730703109751
Coding: 0321008
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005154976
Coding: 0010900
Shop #: WSC 00508 210 88175
End-------------------------(Elapsed Time: 04:18)--------------------------
2007 4.2tdi Quattro Sport.
Valcona black leather, Extended leather, Sports comfort Seats, Fr&R Heated seats, 20" wheels, BOSE, Media Interface, TVIM, DAB, CD changer, Bluetooth, Reversing Camera, Auto dim mirrors, Blinds, Soft close doors, Elec Boot, Keyless entry, Finger print read, TPMS, BI Xenon Active lights, LED indicators, LED puddlelights from door mirror when door closed.
