I've cleaned up your VCDS log a bit.
Removed all the no fault codes and removed some of the less needed information. ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl 2 Faults Found: 049408 - No Communication with Engine Control Module (SAE ECM/PCM) U0100 - 000 - - Intermittent 006273 - Powertrain Data Bus: Missing Message P1881 - 000 - Acceleration Request - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl 2 Faults Found: 02083 - Message for Delay Request 004 - No Signal/Communication - Intermittent 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl 2 Faults Found: 00955 - Key 1 002 - Lower Limit Exceeded - Intermittent 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Flat battery at some point. Clear the code and try again ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl 1 Fault Found: 02244 - Button in Control Head is Stuck 000 - - - Intermittent Button in the roof panel stuck. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl 1 Fault Found: 01520 - Rain and Light Recognition Sensor (G397) 002 - Lower Limit Exceeded - Intermittent possibly due to flat battery. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl 1 Fault Found: 16346 - Control Module - ROM Error What it says. Possible a fault with the cluster EPROM ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None 1 Fault Found: 00664 - Fuel gauge 002 - Lower Limit Exceeded - Intermittent Low fuel and it stopped the aux heater kicking in ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4L0-910-468.clb 2 Faults Found: 01314 - Engine Control Module 01342 - Engine Control Module 2 (Slave 1) 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Another flat battery issue ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl 2 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent 01400 - Suspension Level Control 001 - Upper Limit Exceeded - Intermittent Engine comms issue. Not sure on the other. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl 1 Fault Found: 01370 - Alarm triggered by Interior Monitoring 000 - - - Intermittent Alarm went off ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl 1 Fault Found: 00871 - Bass Speaker Front Right (R23) 011 - Open Circuit - Intermittent As it says. possible fault with base speaker, not pluged in. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Possible fault talking to the engine ECU cable, or just cause of low battery. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl 3 Faults Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent 02273 - Quiescent Current Stage 2 000 - - - Intermittent 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent falt batter and that engine ECU comms again ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl 3 Faults Found: 01299 - Diagnostic Interface for Data Bus (J533) 013 - Check DTC Memory - Intermittent 01477 - System Switched Off 000 - - 01521 - Sensor for Tire Pressure 004 - No Signal/Communication - MIL ON no comms as above but possible a fault with TPMS module not plugged in.
