Old 31st January 2017, 08:28 PM
Jon_viola Jon_viola is offline
Awesome thank you.
I've done a fault by fault reset and will drive again tomorrow then report back.
Some seem to be from the remap and others from a flat battery.
There is a fault code thrown up by the EGR after the delete. I would like to code this out so that the engine doesnt read a fault (and therefore default to a different map).
Can anyone help?
2007 4.2tdi Quattro Sport.
Valcona black leather, Extended leather, Sports comfort Seats, Fr&R Heated seats, 20" wheels, BOSE, Media Interface, TVIM, DAB, CD changer, Bluetooth, Reversing Camera, Auto dim mirrors, Blinds, Soft close doors, Elec Boot, Keyless entry, Finger print read, TPMS, BI Xenon Active lights, LED indicators, LED puddlelights from door mirror when door closed.
Old 31st January 2017, 11:09 PM
EGR if I'm not mistaken needs to be mapped out.
As far as I'm aware that cut be coded out of the ecu.
Old 31st January 2017, 11:18 PM
Yep, EGR has been mapped out but coming up with the component not functioning error code.
I wonder if it needs the plug disconnecting so the ECU doesnt know its there at all....
Anyone know where the plug(s) are?
Or should I just try to set the value as low as possible on the VCDS? How?!
Thanks as ever.
Old 2nd February 2017, 07:42 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I wonder if most of your issues are due to the engine map?
[center]
06 3.0TDI Quattro:
Options:
Old 3rd February 2017, 06:32 PM
Ok so i've been fiddling around with this and now have the EGR and nother codes sorted. I cleared manually and automatically each area then ran the car. The EGR codes came back. I then disconnected them, drove a little and the engine light and codes came back. I then reconnected the EGR's drove and then cleared again. After a short drive they have not come back. I am now left with this:
Thursday,02,February,2017,16:21:36:45075
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
VCDS Version: 17.1.2.0 (x64)
Data version: 20170131 DS267.1
www.Ross-Tech.com
VIN: WAUZZZ4E77N017525 License Plate:
Gateway Installation List: 4L0 910 468
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1D-Driver Ident. -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
So still an issue on the instruments which I can't clear, tyre pressure has been disabled and the fingerprint scanner which doesnt scan.
I can live with these!
I have also changed the air filters (K&N Cheaper then OE so thats what she has) and new Bosch fuel filter.
Afterall this I think she definitely drives better
Old 3rd February 2017, 08:56 PM
ww.Ross-Tech.com
I'd be wary of just looking at the Gateway Installation List
I've found I regularly get my Auto Transmission marked with a Malfunction but the ECU scan has never found a fault of any kind!
I'd also echo what other have said earlier; the 'Clear DTCs' one-click function doesn't seem to work properly [and I'm thinking of reporting it as such to Ross Tech].
I always do my scans with the engine running as with just 'ignition on' you can get all sorts of faults due to the electric load on the battery that the A8s take. Unless you have a really hefty charger supply [12V 30A] on the battery with the ignition off, you'll get strange results.
Also, as others have said, you need to clear the DTCs individually and 'run the car around the block' to see what reappears. Then do a full scan and then put the whole log online ...
Julian
Old 4th February 2017, 04:04 PM
Thanks for this. I just posted the gateway to be breif really. Have been through and deleted DTCs separately raher than in one go and after a drive today the same view as above exists ie EGR issue sorted.
Jon
Old 6th February 2017, 01:19 PM
Hi
I have one persistant error which won't go away. Can anyone tell me what this means?
Thanks
Jon
Thursday,02,February,2017,16:30:29:45075
VCDS Version: Release 17.1.2 (x64) Running on Windows Vista x64
www.Ross-Tech.com
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Control Module Part Number: 4E0 910 951 B HW: 4E0 920 951 B
Component and/or Version: KOMBIINSTR. VDO H82 0530
Software Coding: 0048413
Work Shop Code: WSC 00508 067 57207
VCID: 2447C03FE76BEC61A7-8070
1 Fault Found:
16346 - Control Module - ROM Error
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 70498 km
Time Indication: 0
Date: 2010.06.15
Time: 08:56:29
Old 6th February 2017, 01:59 PM
That error sometimes occurs when a remap has been done. Does that time stamp coincide with the original remap, if you have the history?
What does it show in Advance ID?
The ROM is the 93C76 which stores the odometer reading, CP data and the advance ID stuff. When viewed in a hex editor you can see all this information.
If everything works with the cluster I wouldn't be too worried.
Matt
Old 6th February 2017, 03:42 PM
Thanks so much for your reply.
I'm not sure about the last remap. The guy I bought it from didn't even know it had been done! However my tuner was not impressed- "just a 10% remap"
So that could be the reason. How do I check Advanced ID?
The cluster does seem to work just fine only the finger print scanner doens't work.
Jon
