Old 8th February 2017, 09:58 AM
Thumbs up Job done ...
PDC ECU turned up at 1015am.
Slightly tricky to remove three connectors from the car's ECU until I realised I needed a screwdriver to push the tabs in. Plugged the connectors into the replacement ECU.
Turned ignition on; connected VCDS and scanned the ECU.
Coding needed changing; it was 0201008 [optical parking, automatic, etc.] but I've got fingerprint reader so needed 0301008.
Scanned and found fault code from July 2016; cleared that.
Didn't need to do anything to MMI; just pressed button on dash and visual display came up.
Job done - 25 mins from the time the packet arrived.
Julian
Thanks for spotting that one Matt!
Old 8th February 2017, 11:19 AM
Nice one
Matt
Old 8th February 2017, 06:20 PM
I have just had a thought.
I could use the graphical for checking clearance except when reverse gear is engaged.
Old 16th March 2021, 11:53 PM
Echo's Avatar
Echo Echo is offline
I had a read through the above, and am very grateful for the info, thanks!
A bit old hat to most of you I think, but, seeing as I've recently updated the MMI 2G to 5570, I thought I'd have a go at the graphic PDC upgrade.
The PDC upgrade didn't work until the MMI update was installed.
Old PDC module with just the beeps:
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730410705079
Coding: 0001008
Shop #: WSC 02313 785 00200
VCID: 211FE2479DC914935CC-8074
No fault code found.
New (used) PDC module with beeps and graphics:
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08740819200442
Coding: 0201008
VCID: 2313E84F87D506834E0-8076
And now, when reverse gear is selected, the screen shows this:
Well I think it's pretty neat anyway
ID:	25808   Click image for larger version
ID:	25809   Click image for larger version
ID:	25810   Click image for larger version
2004 A8 D3 4E2 3.0ltr Petrol............baby A8
Old 17th March 2021, 08:35 AM
Glad you got another upgrade sorted, and thanks for posting the detail, it may well help someone else in the future
Old 17th March 2021, 09:20 AM
Echo's Avatar
Thanks IT.
Not bad for £20
Old 17th March 2021, 11:17 AM
homer simpson's Avatar
Bargain! Now if you really want to go the whole mile, add the camera
Old 17th March 2021, 11:42 AM
Echo's Avatar
Now that would be very nice Mr Simpson!
Very expensive though eh?
Old 17th March 2021, 04:48 PM
Camera, wiring, boot trim and coding. If your module doesn't support it (haven't looked) then that too!
Old 17th March 2021, 05:38 PM
Echo's Avatar
Which module is that?
