Old 13th February 2017, 02:38 PM
Originally Posted by speed_demon1978 View Post
Hi Matt - do you mean a pic of my driver door open and then the centre instrument cluster image showing the passenger door open instead?
If you can, yes. Never seen that before with a wrong graphic in the instrument cluster.
Matt
Old 13th February 2017, 04:58 PM
Hi Julian, just to point out that you've mentioned door ECU's then listed seat ECU's.
The door ECU's are specific to their location:
Driver (0x42) module J386 hw 4E2 907 289
Passenger (0x52) module J387 hw 4E2 959 801
Matt; thanks for pointing that out.
Forgot that door and seats both had ECUs.
BTW; my car has 4E2 959 802B [Driver 42] and 4E2 959 801B [Passenger 52] and both have the same coding; as you'd expect.
Julian
Old 13th February 2017, 05:03 PM
Tried looking for the settings in the main options as well as hidden green menu to no avail though for changing mpg which currently reads as xx l/km (l/100km.
Speed_Demon; am I misunderstanding something here?
There isn't a specific setting for MPG; I presume this is set from the units in the Car menu.
Julian
Old 14th February 2017, 08:57 AM
speed_demon1978 speed_demon1978 is offline
Julian
Hi Julian - I can`t see an option for changing the units in the car menu at all. Only get a few options to change like speed (in mph or km) etc.
In the instrument cluster the fuel consumption is displaying as xx l/km (l/100km) which I can`t seem to change.
In the hidden menu I get this under the MMI settings (see attached pic)
Current: MY57 Audi A8 3.0 TDI Quattro SE, Silver, Black Comfort Heated Leather, MMI High 2G, Bluetooth, Nav, Voice Control, AMI, Rear Camera, 6CD, 20 inch 9-spoke alloys [in Black], Folding Mirrors, 3-spoke S Line steering wheel + mods to come
Old 14th February 2017, 05:47 PM
I was referring to the changes you can make in the 'Setup/Measurement Units' MMI Menu. This has a 'Distance Unit' and 'Speed'. If you have 'Distance' set to "miles" and 'Speed' to "MPH" then your 'l/km' in the cluster is a different problem I'm not able to help you with.
I think you're going to need a VCDS scan anyway, as to really try and check these two issues out, members of this forum will want to see part numbers, HW/SW versions and coding settings of the Instrument panel and door ECUs to make progress ...
Julian
Old 14th February 2017, 08:16 PM
I'm getting more and more confused with your issues if I'm honest.
See attached photo for changing the units
Press Car > Setup > Setting in top right corner and then go to Meassuring Units
If that won't solve the problem there could be incorrect coding in your cluster or other units.
About the doors.
I wonder if you have a passenger unit fitted on driver's door or this unit coded as passenger.
A full VCDS scan would be best place to start mate.
What version of MMI have you got by the way ??
Old 15th February 2017, 08:22 AM
Julian
Hi Julian - all of those settings are set correctly from what I can see. So will probably need a VCDS scan to see what the root cause is. There doesn`t seem to be any other option in the 'normal' car menu system for me to change the fuel consumption figures so I think it must be linked to my car seemingly being set-up as a LHD in the software somewhere with the door issue I have in the cluster and also the LHD set-up I can see in the green hidden menu under MMI.
This is the version info from my car:
SW: D3-HU 55.7.0 0835
HW: D3-HU 6300D2.0
FC SW: 06231AFC6AB320050
FC PS: 0050 FC HW: H01
Old 15th February 2017, 08:29 AM
So, you have the latest MMI version which is good, at least we know its not the MMI software glitch.
Now, if you can access green menu, go to DIAG SETTINGS and untick linkslenker which LHD, if its not in in DIAG then check all the other menus and submenus please.
Old 16th February 2017, 08:55 AM
Hi mate - have unticked that option already to no avail. Spoke to my local Audi who said the instrument cluster has nothing to do with the MMI (W.T...?) So does not give me much confidence. The car is in with them today for a free health check and looking into this issue I have so will see how it goes.
Old 16th February 2017, 08:38 PM
Messed up wiring on the main plug??
Possibly has been messed around and pins are other way round on the pain connector.
Unlikely, but without good history of the car and no VCDS to identify if left door is wired as left door and vs I hope its just something along the lines of coding or adaptation channels.
Let us know, if still no luck I will jump on mine and see if I can ''create'' your issue on my car coz then I will know where you need to go and what value you must put to get it finally fixed.
