Old 8th February 2017, 11:14 AM
A8 Ian A8 Ian is offline
Default Steering judder on full lock
Hi All,
In my D3 on full lock I had the usual quattro judder, on my D4 the lock is much better than the D3 but on full lock I get this horrid feeling like it's skipping across the road..
Kind of like when you see an artic lorry go full lock and you can see the wheels simply can't turn so they kind of scrub ..
Well I can't think how to explain it but it's not very nice..
Is this normal or do I need to get it to Audi?
At car parking speeds I should point out!
Thanks
Ian
Old 8th February 2017, 12:10 PM
Doesn't sound normal to me, very occasionally I have felt a bit of a judder on full lock - but it seems surface dependant - not all the time
Old 8th February 2017, 05:33 PM
Joe2.0E Joe2.0E is offline
Agree, as you describe it, it doesn't sound normal. I consider the "AWD" judder on a D4 is less noticeable than on a D3.
Old 9th February 2017, 05:28 AM
Interesting. . I will have to try it on a multitude of surfaces and see if it's that or something that is a problem.
Thank you i will get it checked out
Old 9th February 2017, 07:37 AM
Check for uneven tyre wear, won't take much scrubbing to show up that way
Old 10th February 2017, 06:45 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Is it during all outside temperatures? My D3's front end with 255 section tyres does sort of scrub on full lock when its close to 0 degrees at low speeds. First time I thought i'd hit something!
2007 Mini Cooper S R56
Old 11th February 2017, 01:28 PM
Well it has been cold of late I guess. Still doing it mind
Old 24th February 2017, 12:21 AM
JAM311S JAM311S is offline
Yes I get this with 21" wheels quite badly
Passengers always comment on it,
Old 24th February 2017, 09:35 AM
I'd not really considered it until now, but I'd agree that the D4 did have a good steering lock, but I definitely felt there was more transmission wind up at the extremes and could sense the tyres scrubbing.....
It was more prominent that I recall on most Audis I've had but for whatever reason I must have subconsciously decided it was plausibly by design as I'd not remembered until seeing this post....
Old 26th February 2017, 06:11 AM
Very interesting. .. I must ask my friend to report back he's just bought a new 2017 S8 I'd be interested to see if it does it on a new car or its just my milage/age related wear
Thanks again
