Old 24th February 2017, 08:02 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Really good bit of kit, use it on D2 S8 and it works on a 2012 Q7 as well
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 24th February 2017, 09:20 PM
gninnam gninnam is offline
Agreed, for the money its good - use on my TT - recommend
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 27th February 2017, 12:21 PM
Simonbartlett Simonbartlett is offline
When i plug this in will it list modules ( ecu's ) and will it tell me their part numbers ? I need to know what steering module my a3 has for fitting Cruise.
Thanks
Owner of a 2008 A8 3.0tdi SE
Old 27th February 2017, 01:13 PM
Thanks
I've just checked with mine and it would seem so.
After you've plugged it in and connected via the app, it scans for modules. You'll then get a list of all the modules it found. If you select the relevant module, then select 'info', it seems the part number is listed there.
A few screenshots ...
Name:	2017-02-27 13.58.45.png
ID:	15779 Click image for larger version
Name:	2017-02-27 13.58.55.png
ID:	15780 Click image for larger version
Name:	2017-02-27 14.00.09.png
ID:	15781 Click image for larger version
Name:	2017-02-27 14.01.11.png
Old 1st April 2017, 06:25 PM
chrisc201 chrisc201 is offline
Hi there,
Thought I'd piggy back rather than create a new thread.
I've developed an intermittent cut out on my mmi (2006 A8) which from a bit of reading a gather is likely a faulty component impacting the MOST ring.
Would OBDeleven read the necessary information (assuming a fault has been stored) to help pinpoint the issue? Also, the tv has obviously been coded out and I'd like to put it back on so I can use the aux inputs, again would this be possible via OBDeleven?
Cheers,
Chris
Old 8th April 2017, 08:45 AM
Intermediate cut outs on the MMI is most likely to be a loose connection behind the glovebox somewhere on the optical loop, probably best to take out the glovebox and then check the visible connectors to see that they are all seated properly and not loose
Old 12th April 2017, 06:51 AM
Thanks for suggestion, got a scan lined up for Friday morning so I'll see where that leads me... I did have a look on the pdf's about removing glove box and got a little intimidated!
Fingers crossed something simple / cheap!!
