Old 2nd March 2017, 08:57 PM
manca manca is offline
Thanks John yes if I can get away with that it's the best of a worst case. I have pm'd Marcin who is as always too generous with his time and expertise. I'm feeling slightly more optimistic thanks to the people on this forum. It's a gem of a place.
Old 2nd March 2017, 10:11 PM
Sorry mate, been busy but I'm back now.
Will PM you in a minute.
Old 2nd March 2017, 10:52 PM
H-M3 H-M3 is offline
PM me your post code please.
I'll see if can pop in over the weekend.
How about weekdays between 11-2pm?
It would most likely be weekend anyway but just in case.
Any excuse to drive his V10
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 2nd March 2017, 11:01 PM
Well
You can't go wrong with mixing pleasure and helping someone in need.
Plus I'm desperate to go for a good drive. Not necessarily across London in traffic, but I will make it fun
Old 3rd March 2017, 12:21 AM
Well
I'm lost for words, but obviously very grateful. I will be home whenever it suits you Marcin
Old 3rd March 2017, 10:12 AM
Just been looking at prices, the 'scrap' car is probably worth more than you think, but looking at the prices that the D3 Tdi's are holding, the difference between the two suggests its worth fixing.
As others have said, its almost unheard of for the 6 speed boxes to give up the ghost, but then, the 3.0 Tdi D3's tend to keep going forever too, so 'boxes are not as common as you'd first think.
I see the sponsors have one available, but you'd need to check your engine code:
http://www.ebay.co.uk/itm/132074319334
I would encourage you to call them and chat pricing - There should be some decent movement on big ticket items, and it will be a good box from a good car that drove into the workshop under its own steam, and wasn't scraped off the road after trying to wipe out a tree and losing....
Hope you get it sorted
Old 3rd March 2017, 11:30 AM
If Marcin confirms suspicions on the box I think he knows some reputable folk local-ish to you that could swap a box?
Alternatively see what David can quote you for a box swap:
http://www.dsautowerks.co.uk/
Although obviously it'd involve getting it to Crawley on a transporter.....
Old 3rd March 2017, 11:37 AM
Ian, Adrian many thanks your input is much appreciated
Old 3rd March 2017, 12:36 PM
Hi
Sorry, had an absolutely manic day today.
So, I will be with you tomorrow morning.
Spoke to my Audi garage in Harrow and two weeks ago they have done two swaps on A8, one 3.0TDi and one Q7 3.0Tdi.
Bad news is that on Q7 you don't need to drop the engine down where on 3.0TDi A8 you have to drop the engine with the suspension frame in order to disconnect gearbox from the engine. Cost of the swap inc driver which is part of the mechatronic inside the gearbox is £960.
But, you can't just swap the gearbox as it won't work with the others gearbox driver or control unit however you want to call it.
You have to remove your original driver unit (from mechatronic) and swap it with the one on the new gearbox. If you just swap the gearboxes it won't work, simple.
So the one main thing to hope for is for your driver on your gearbox to not be faulty as new complete mechatronic is £4k. If it's mechanical and electronic side is fine then it's a ''simple'' job, they do these jobs all the time.
Before making any decision we can always send them VCDS scan so they can have a look at it first, before transporting car to them if you decide to go with them or any other place.
Guys, what's the best plan for tomorrow?
- Full scan, save it and clear all the faults.
- Delete all the faults one by one or just engine and gearbox??
- Start the car, attempt to drive until it goes into limp mode and do another full scan or just gearbox and engine?
That is obviously if car will move at all after loosing drive completely as Adam said. It could be mechanical or electronics just cut the gears off completely for safety ?!
I am simply going there to help a forum member and give him so hope and starting point in process of making decision.
I've got very little understanding of mechanics so if I used a wrong term don't jump on me straight away as I always could misunderstood something.
What I would say is that they know what they are doing amd what needs to be done re gearbox swap so it works, their reputation is impeccable and they have no time for BS and I know them for 6 years now and I will vouch for their work and what they say.
Old 3rd March 2017, 02:24 PM
It's sounding very much like a mechanical failure to me, but I suppose it's possible the box electronics are trying to protect the gearbox if they've detected an issue?
I don't think clearing the faults, once saved, will make any difference.
Ref the mechatronic coding - presumably with the right software this can be recoded, even for a 2nd hand unit? I imagine it's a form of component protection to prevent theft?
