Old 10th March 2017, 03:09 PM
Bulb had exploded so my offside light unit is full of broken glass and metal from the shutter.
Not sure if I can somehow suck that out through the bulb fitting hole with a small tube attached to a vacuum cleaner or will need to dismantle it.
Is dismantling a reasonable job?
Hi Andrew
Dismantling is relatively straightforward, but the unit does need removing from the car before you can take the lens off. It's covered in the refurb thread I did on the bi-xenons.
It would probably be wise to have the alignment checked after refitting as there's reasonable movement on the fixings.
A
