Old 16th March 2017, 01:27 PM
H-M3 H-M3 is offline
Same.
H-M3, what issue do you have, does the DVD reader not recognise the DVD?
If you want, PM me your address and I'll burn and send you a DVD that works in mine...
It burns all good but then when I insert in DVD reader it says insert a valid nav DVD or so
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 18th March 2017, 05:08 PM
You need a single layer DVD - the MDS file works with Alcohol 120% burning software as a setup config, but you can use any DVD burning software like Nero that supports ISO. What you don't want is the ISO file burned onto a DVD!
I have the full version downloaded from a Mega link, but don't have a D3 to test it on yet (Borys if you read this drop round and I'll give you one)
Adrian
Yes you do Adrian!! Ahem hint hint
Old 18th March 2017, 06:09 PM
Thanks to all for their patience I have managed to crack it eventually! Just used the Macs burner via disk utility.
Old 18th March 2017, 07:44 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Didn't need the discs I sent in the end then I take it?
2007 Mini Cooper S R56
Old 18th March 2017, 08:19 PM
John thanks for the discs and to everyone else who offered to send me copies too. John gonna keep your ones for myself as the one I managed to burn gave to a friend for his D3
Old 18th March 2017, 08:20 PM
Johnmed's Avatar
Just glad you got sorted mate.
Old 18th March 2017, 08:44 PM
I.T is one of my Gremlins and I was frustrated when I was losing! Man thing I guess.
But seriously thanks buddy!!!
Old 6th May 2017, 07:47 PM
mannyo mannyo is offline
I decided to see if I could get my Nav working with a burnt 2017 DVD-R, I used my mac running macOS, in macOS you use finder to burn ISO files to disc as its been removed from Disk Utility.
Before putting the burnt disk into my D3, I put a CD lens cleaner in the DVD drive, waited for it to say check Navigation DVD and removed the cleaner. I repeated this at least a dozen time, I wanted to make sure the little brushes on the cleaning disk had been passed over the laser multiple times. You can hear the laser move back and forth, so I was sure the brushes would be picked up at some point.
Then popped in the 2017 disk, and it read just fine. I then plotted a route to John O groats from where I am, and that worked as well and I could display the map with no issue.
I'll try a drive next weekend and see if it does what all DVD-R's have done in the past which is eventually stop working. Looks promising at this point though.
Manny
Past
Old 7th May 2017, 09:47 AM
If it does stop working again it'll either be the quality of the media, or most likely a tired laser
Old 7th May 2017, 09:49 AM
Johnmed's Avatar
From what I've read the best chance of success is a Dual layer DVD that is not in any way translucent burnt at a slow speed. I've had no issues myself with just cheap DVD-Rs burnt fast that you can see through.
