Hello Guys,
maybe you can give me a little hint where could be an issue ![]() Last Friday, when I was switching from comfort to Lift, front Axle get stuck (car was not used for two months) and I see VCDS error: 01400 - Suspension Level Control 001 - Upper Limit Exceeded - Intermittent Freeze Frame: ![]() compressor looks fine to me , I did test and filled the reserve tank up to 14 bars - I can also release the pressure from it. If I pump the rear axle up to 6.5 bar (I see that car it's leveling) I can also lower the rear suspension through VCDS. Unfortunately with Front there is something wrong. Before pumping up, there were 2 Bars, after bleeding the value has changed to 0.98, but no difference in heigh. Later I fill it up to 9.5, and front changed height from 57mm to 95mm and stuck there! Once again releasing air (bleeding in vcds) has no effect - I see that it's releasing air from 9.77 to 0.98 very quickly aprox. in 1 second- for comparision, rear axle take at least 10 seconds, and I can see values slowly droping in steps, from 6.5, 6.18, 5.92 and so on... ![]() ![]() Last edited by migelus; 7th May 2017 at 05:23 PM. |
