Have you used VagCom on it yet?
I would recommend having it scanned before spending any money as there are a couple of processes that will help pin down the culprit. VagCom may tell you which cylinders are misfiring. You can then swap the plugs between cylinders and see if the misfire follows the plugs. Or you can change HT leads and see if the misfire follows the HT leads. If you don't have VagCom, there should be someone in your area that can help.
Tags |
audi 2.8 a8v6 fwd 1995, audi s8 2001 |
