Old 29th May 2017, 06:47 AM
Prefferle Prefferle is offline
Default D3 V10 brief rough idle during warm up.
Hi folks, I've just completed the valve cover gaskets and put it all back together and I'm now experiencing a very rough idle that lasts about 15sec just when the auxiliary air pump stops and the rpm starts to drop to normal idle. After the 15 sec the engine us smooth as silk. If the engine is already hot then all is fine. This problem was not their previously. Any ideas in what I should be checking for?
All pipes connectors and linkages appear to be in place.
Thanks and kind regards,
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
Old 29th May 2017, 07:23 PM
richardracer richardracer is offline
Default Bad idle on cold start up
Hi Badderle,
I had something similar on my S8 v10. Mine was caused by a small air leak from one of the pipes at the back ( the fat braided one passenger side at the back. Replacing it gave me a smooth fast idle until aux air/fuel supposed after 15 seconds. Expensive hose around £90 from memory at stealer prices.
My car is Also 2006 S8 v10 with 165,000 miles on it.
Good luck
Richard
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 30th May 2017, 11:12 PM
Originally Posted by richardracer View Post
Hi Badderle,
Good luck
Richard
Thanks Richard, I'll have a run through of the stuff I took off the England me again including the air inlet hoses.
Thanks,
Stephen
Present cars
