This is what my car is throwing up at the moment... Any ideas which part(s) to replace
![]() She's running fine (power wise) just the orange light on the dash showing engine fault?? Only thing I would say is she seems to have aquired a "bass line" ![]() ![]() ![]() Many Thanks ![]() 005504 - Throttle Actuator (Bank 1): Malfunction P1580 - 008 - Implausible Signal Freeze Frame Fault Status: 01111000 Fault Priority: 0 Fault Frequency: 6 Time Indication: 0 Date: 2010.06.12 Time: 17:07:35 Freeze Frame RPM: 0 /min Torque: 0.0 Nm Voltage: 12.31 V Duty Cycle: 82.9 % 004203 - Throttle Valve: Stuck or difficult to move P106B - 001 - Upper Limit Exceeded - Intermittent Freeze Frame Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 254 Time Indication: 0 Date: 2010.06.18 Time: 22:11:34 Freeze Frame RPM: 777 /min Torque: 93.6 Nm Voltage: 4.080 V Duty Cycle: 61.2 % Duty Cycle: 7.5 %
07 Silver D3 A/S8L Quattro ![]() ![]() |
P1580 Throttle Position Actuator (V60) dirty/stuck/faulty P106B is P106B Could be - 1) Wiring/Connectors from/to Throttle Body Control Module to Engine Control Module faulty OR 2) Throttle Body Control Module Damaged and/or Moving Difficulties Click on the code links for a fuller explanation in both cases HTH ![]()
Try to clean the throttle body.
Remove the inlet pipe and clean out with a brake-cleaber soaked rag. Make sure you get right into the corners of where the mounting rod is and DON'T DROP ANYTHING IN OR GET YA RAG STUCK IN IT!!! Breather gases can make oil vapour and carbon deposits build up in the housing that eventually restricts the throttle plate's movemnt. Cleaning it may help but you then need to re-adapt it. Plug in VAGcom, ignition on. Into Engine and select BAsic Settings. Type in 060 in the block field and hit return. It will show some movement in terms of either a percentage of travel or a current draw in milliamps. In the right hand block it will say "ADAP RUN, then ADAPT OK when it's finished. You'll here the valve moving. Once it's done just exit and clear any faults. Then start the car WITHOUT touching the throttle pedal. If this doesn't work you may have a duff wire or knackered valve! Good luck. p.s, I'm assuning you have the 40v not 32v, if you have a cable operated throttle as a possed to full drive by wore one then the basic setting figure os 098 istead of 060 but same procedure. |
![]() I was understanding until what I have highlighted bold. ![]() It's a 3.0 TDI if that helps ![]() When I pop the engine cover off I can see a few bits moving backwards and forwards... this in in perfect timing with this "basey" noise I have coming from the exhaust ![]() Bloody car! Every time I polish it it wants something done to it, whether it be brake pads or a bloody service! lol ![]() Good job I love her! ![]()
AH!!! My bad!
I never even considered it being a diesel! In that case it will be due to a severe carbon build up within the intake manifold. This may be a bit more involved though due to this engine and it's design. Be sure to buy your diesel somewhere good - cheap fuel causes huge build ups and can damage your common rail injectors quickly!! Always try to use Shell or BP where possible - NEVER any supermarket or Spot fuels ect! You are gonna have to have inlet tract off and physically remove all the build up I would say with those faults. Apologies again for assuming your motor was petrol! I should have read up as on many earlier posts you are pretty clear!! ![]() |
can I put a fuel cleaner in to help??? Any you would recommend???? I have to admit I have used sainsburys fuel recently??? Should I go and use V power Diesel from shell??? Thanks for all your advise-if you were closer I'd be bringing it to you guys! lol
