Old 13th June 2017, 10:52 PM
Question Anyone any idea why my Parking Sensor Display no longer appears? ...
I upgraded my 2005 A8's parking sensor ECU in February to the C revision that shows the display on the MMI screen. It worked fine since then until today, when I noticed that the display no longer appeared whenever I used Reverse gear or pushed the button on the dash
I've scanned the ECU and there's no DTCs and the coding hasn't changed somehow, so I'm puzzled why it no longer works!
Code:
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0030
   Revision: 00H12000    Serial number: 08720610203793
   Coding: 0301008
   Shop #: WSC 02313 785 00200
   VCID: 234588EDE204395F59-8076
No fault code found.
Anyone have any idea of any tests to try or settings to check please?
Julian
Old 14th June 2017, 12:54 AM
H-M3 H-M3 is offline
try doing a reset of the mmi, also i recently noticed when battery low the settings can be lost you you should go to settings and see if parking graphic is selected on mmi.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 14th June 2017, 11:59 AM
Lightbulb
... go to settings and see if parking graphic is selected on mmi.
Thank you
I didn't realise there was a setting for the graphic display, as it had automatically appeared once I updated the ECU.
What do you know? It was turned off - which is a bit strange as I certainly never turned it off
Easily sorted ...
Thanks - Julian
Old 14th June 2017, 05:41 PM
We learn new things everyday
