Old 22nd June 2010, 04:18 PM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
Default Hmmm Vag Com Help.....
This is what my car is throwing up at the moment... Any ideas which part(s) to replace
She's running fine (power wise) just the orange light on the dash showing engine fault??
Only thing I would say is she seems to have aquired a "bass line" One thing I might add is the car has good rythem
Many Thanks Bex
005504 - Throttle Actuator (Bank 1): Malfunction
P1580 - 008 - Implausible Signal
Freeze Frame
Fault Status: 01111000
Fault Priority: 0
Fault Frequency: 6
Time Indication: 0
Date: 2010.06.12
Time: 17:07:35
Freeze Frame
RPM: 0 /min
Torque: 0.0 Nm
Voltage: 12.31 V
Duty Cycle: 82.9 %
004203 - Throttle Valve: Stuck or difficult to move
P106B - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 254
Time Indication: 0
Date: 2010.06.18
Time: 22:11:34
Freeze Frame
RPM: 777 /min
Torque: 93.6 Nm
Voltage: 4.080 V
Duty Cycle: 61.2 %
Duty Cycle: 7.5 %
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 22nd June 2010, 05:56 PM
Many Thanks Bex
Freeze Frame
Fault Priority: 0
Fault Frequency: 6
Time Indication: 0
Date: 2010.06.12
Time: 17:07:35
Freeze Frame
RPM: 0 /min
Torque: 0.0 Nm
Voltage: 12.31 V
Duty Cycle: 82.9 %
Freeze Frame
Fault Priority: 0
Time Indication: 0
Date: 2010.06.18
Time: 22:11:34
Freeze Frame
RPM: 777 /min
Torque: 93.6 Nm
Voltage: 4.080 V
Duty Cycle: 61.2 %
Duty Cycle: 7.5 %
P1580 is
P1580
Throttle Position Actuator (V60) dirty/stuck/faulty
P106B is
P106B
Could be -
1) Wiring/Connectors from/to Throttle Body Control Module to Engine Control Module faulty OR
2) Throttle Body Control Module Damaged and/or Moving Difficulties
Click on the code links for a fuller explanation in both cases
HTH
Old 23rd June 2010, 08:58 AM
Just_Ben Just_Ben is offline
Try to clean the throttle body.
Remove the inlet pipe and clean out with a brake-cleaber soaked rag. Make sure you get right into the corners of where the mounting rod is and DON'T DROP ANYTHING IN OR GET YA RAG STUCK IN IT!!!
Breather gases can make oil vapour and carbon deposits build up in the housing that eventually restricts the throttle plate's movemnt.
Cleaning it may help but you then need to re-adapt it.
Plug in VAGcom, ignition on. Into Engine and select BAsic Settings. Type in 060 in the block field and hit return. It will show some movement in terms of either a percentage of travel or a current draw in milliamps. In the right hand block it will say "ADAP RUN, then ADAPT OK when it's finished. You'll here the valve moving.
Once it's done just exit and clear any faults. Then start the car WITHOUT touching the throttle pedal.
If this doesn't work you may have a duff wire or knackered valve!
Good luck.
p.s, I'm assuning you have the 40v not 32v, if you have a cable operated throttle as a possed to full drive by wore one then the basic setting figure os 098 istead of 060 but same procedure.
Old 24th June 2010, 05:03 PM
A8L Chick's Avatar
Good luck.
Thank You, I will try this
I was understanding until what I have highlighted bold.
It's a 3.0 TDI if that helps
When I pop the engine cover off I can see a few bits moving backwards and forwards... this in in perfect timing with this "basey" noise I have coming from the exhaust Now, not sure if this is anything to do with it, but it seems I have VERY slight power surges when on the throttle (steady throttle i.e not moving throttle position)
Bloody car! Every time I polish it it wants something done to it, whether it be brake pads or a bloody service! lol
Good job I love her!
Old 25th June 2010, 07:24 AM
AH!!! My bad!
I never even considered it being a diesel!
In that case it will be due to a severe carbon build up within the intake manifold. This may be a bit more involved though due to this engine and it's design.
Be sure to buy your diesel somewhere good - cheap fuel causes huge build ups and can damage your common rail injectors quickly!! Always try to use Shell or BP where possible - NEVER any supermarket or Spot fuels ect!
You are gonna have to have inlet tract off and physically remove all the build up I would say with those faults.
Apologies again for assuming your motor was petrol! I should have read up as on many earlier posts you are pretty clear!!
Old 25th June 2010, 04:55 PM
A8L Chick's Avatar
can I put a fuel cleaner in to help??? Any you would recommend???? I have to admit I have used sainsburys fuel recently??? Should I go and use V power Diesel from shell??? Thanks for all your advise-if you were closer I'd be bringing it to you guys! lol
