Old 4th July 2017, 07:18 AM
carmel120 carmel120 is offline
Default rear parking camera
just for people installing a rear camera this one looks like a direct fit.
I purchased one of ebay and I had to spend a couple of hours with a dremmel to make it fit don't like the non oem looks so this looks good.
https://www.aliexpress.com/item/Car-...08.3.10.YnZVaF
Old 4th July 2017, 07:58 AM
Johnmed's Avatar
Johnmed Johnmed is offline
Good find. I've been there with the generic Dremel type thing wondering why things can't ever be simple with Audi.
2007 Mini Cooper S R56
Old 4th July 2017, 01:24 PM
yea got mine fitted today using the xcarlink for the reverse switch pity I didn't see this camera before I started using a camera that did not fit right and the led light part doesn't even work it just started to flash then nothing
Old 4th July 2017, 01:44 PM
EDIT: Looks like it's not for the D3
Anyone tried this camera?
http://www.ebay.co.uk/itm/351409588411?
Matt
Old 4th July 2017, 09:01 PM
Simonbartlett Simonbartlett is offline
Whete do you connect this and what else is required ?
Owner of a 2008 A8 3.0tdi SE
Old 5th July 2017, 10:17 AM
Joe2.0E Joe2.0E is offline
Pretty sure the car needs to have a TV Tuner to display the output on the MMI Screen. The Parking Sensor Module might also needed to be changed to enable the camera display when you select Reverse but it may be just coding to enable this function.
Old 5th July 2017, 10:22 AM
Johnmed's Avatar
Much easier if you have a TV tuner in the boot. Without you need an interface, like this:
https://www.ebay.co.uk/itm/262742227637
And to wire it all in behind the glovebox before the MMI, like I did.
Old 5th July 2017, 10:29 AM
What about with the 3g mmi ? I have sensors front and rear with the display but no tv. Its a 2008 se.
Old 5th July 2017, 10:31 AM
Those cameras are seriously cheap if they are any good. Interface makes it expensive if you don't have a Tuner.
Would it make any sense to buy a 2nd hand Tuner instead ?
Old 5th July 2017, 10:42 AM
The OEM TV's send an analogue signal down a coax to the front to the MMI Control head. So you would still need an MMI control head with the FBAS connection to add the OEM TV module. Non-TV and non-RVC A8's don't have this connection on the MMI control head. The Control Head has component protection so if swapped this would need to be removed by the dealer, to add further costs. John's method is best as his module sits between his existing MMI control head and the screen... Actually this is not so dissimilar to the Japanese spec A8 as they have an LVDS switch at the same location to switch for the Jap spec sat nav.
Matt
