Old 10th July 2017, 09:12 PM
karlcossy karlcossy is offline
Default mmi problem no screen
mmi now stopped working while fitting interior was all ok
splash screen starts up then goes black no fuction on mmi panel
vcds cant see half the kit nav cd tuner etc and also noticed there is no light in the fibre cables anybody got any ideas please
Old 14th July 2017, 05:44 PM
Joe2.0E Joe2.0E is offline
Start by checking your battery. The MMI can shutdown various bits if its power source is not up to scratch. Next step would be trying to figure if one of the mmi connected modules such as Bluetooth, Amp etc. has gone faulty. If one goes down, it all goes down. You can buy a fibre optic loop from Audi to bypass each module in turn to isolate the faulty one. Scan/Clear faults as you go.
The MMI control panel can also play up if someone has spilled something on the buttons. It's a poor design having cupholders right next to the mmi panel.
Old 15th July 2017, 06:57 AM
Tiburon3 Tiburon3 is offline
Good morning.
It seems to be a cut in the optic fiber loop, by any reason, the loop is open.
If I remember well, you were changing the full interior of the car. I assume that you dismantled the CD changer / Audi AMI modules. Try to start by there, maybe you forgot to connect the fiber optics connector.
Cheers from Spain
Old 15th July 2017, 08:07 AM
Just for information so you can make sense of what you see re. 'red light'.
The optical loop normally goes:
1) Control Head [aka Interfacebox] in the dash
2) Phone - passenger floor
3) Boot - Amp, Nav, TV, Radio
4) Glovebox - Media 1, Media 2 [typically CD, AMI]
5) Gateway - dashboard
You can check the path on a working MMI by using the MMI hidden 'Red screen' - the device numbers are, I believe, in loop order.
Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver.
Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years!
