Old 7th August 2017, 08:11 PM
And check the phone settings too, see what devices it has recognised as connected via Bluetooth - work out if it's using the phone microphone or the car one.
I don't know where the D3 microphone is, but somewhere near the sunroof switch would be my guess.
Old 8th August 2017, 06:35 AM
Have you or someone previous retrofitted voice control, or does your car have voice control and the phone module been replaced.
There is a difference in mic connections depending on voice control or not.
If you do not have voice control then the microphone is connected to the bluetooth module directly.
If you do have voice control, then the microphone is connected to the voice control module instead.
As Marcin found out when retrofitting voice control, correct microphone routing and coding of the modules is needed otherwise nobody can hear you, read the long thread here.
http://forum.a8parts.co.uk/showthread.php?t=7651
Old 8th August 2017, 08:25 AM
Conquistador's Avatar
Isn't the microphone up in here?
In the MMI phone settings I'm sure there's an option to for rear passengers' microphone too, so is there also one in the back somewhere??
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
