#31
Its all right, i havent a clue what crowd sourcing is really. I think its a modernism for an old fashioned whip round and get your mates to help you out.
P.s In case you are going to ask, I'm saving for a modified exhaust and some Yellowstuff pads ![]()
#32
![]() The car itself is actually in really nice condition though. No seized bolts, everything coming apart nicely, etc mostly because it's all been coated in engine oil for years ![]() ![]() ![]() Sadly, I have added the steering rack to the list. After flushing a gallon of ATF through it, its still coming out like school custard, and the rack still doesn't feel right. As described by HP earlier, it just springs back to the centre with no resistance. I've agreed with Dean that while the engine is out its best to change it for safety's sake if nothing else. Plus we'd be really ****ed if I put the engine back in and the rack failed completely a few weeks later! ![]() This is what the original fluid has settled to: ![]() I've dropped the column in preparation for the rack coming out. You can't disconnect the column from the rack with both of them bolted in place, and I can't open the doors on an A8 with it up on the lift, so I've disconnected the column now which means the rack just unbolts from the engine bay later. ![]() The header tank has seen better days. ![]() As have the brake discs ![]() Everything on top of the engine is now disconnected, ready for work underneath ![]() Suspension comes off as an assembly. Its much easier to break down in the vice, and it makes taking the engine out a whole lot easier without all this stuff in the way! ![]() Last edited by MikkiJayne; 14th September 2017 at 08:43 AM. |
#33
Amazing work!
Speaking of oil leaks, I may have a leak of gearbox oil probably the lines that go to the radiator, I keep having to top up gearbox oil, and its coated the undertray in heavy sticky oil. If you are interested in having a look I'll pm you to see when you are free. Last edited by Goran; 14th September 2017 at 08:58 AM. |
#34
Ooer. One of the two oil cooler lines for the manual gearbox is NLA now. Lets hope its the other one! I'll be conjuring up an aftermarket solution for those lines in October though so we can solve it either way
#35
Kudos where it's due. I'm enjoying this thread with the photos and update
![]() How easy is it to slip in a V8 ;-) Here's a 2.8 that had an oil leak, the owner neglected it until the cam shaft became so staved of oil it heated at the main bearing and snapped.
#36
Have a word with Mike as i gave him one a while back, twin exit
#37
After the other suspension assembly came off its underneath to disconnect the exhausts and prop. Pretty oily under here...
![]() Yes, I cut the cats off with the sawzall ![]() ![]() Rear seal leaking, of course. ![]() Mark the prop and output flange so it can go back together the same as it came apart. Top tip: When removing these bolts on your own (or with a helper who doesn't want to get oily or go under the car) use the handbrake to hold the prop still. Take the first three bolts out, then release the handbrake and rotate the prop 180°. Put the handbrake back on, then take the other three out. Simples ![]() ![]() The CV joint is usually stuck to the flange by the rubber seal. A sharp tap with a chisel in this groove will break it free ![]() Lift the car off the engine & gearbox ![]() Ready to start dismantling and cleaning ![]() ![]() We're about 8 or 9 hours in here. As this is the first time I've worked on this car I'm taking my time and checking everything as it comes apart. I've probably spent at least an hour changing oily gloves too ![]() |
#38
This is gripping stuff (for me at least).
I think you should have taken Edd China's place on Wheeler Dealers ![]() Perhaps we should have a regular time when we all tune in to see the latest installment ![]() Oh! And what does NLA mean? "Ooer. One of the two oil cooler lines for the manual gearbox is NLA now" Is that serious in the grand scheme of things?
Dean Future work on "Red Dwarf": Fridge, solar sunroof, radio-controlled clock, interior and exterior dimming mirrors, Alcantara headlining/pillars/rear shelf, rear US outer lights, passenger memory seat, rear electric (lumbar and headrest) heated seats, Servotronic. __________________ Current: 2002 A8 D2 S8 FE - "Red Dwarf" - Misano Red - Platinum/Silver Interior, PDC, Sat Nav Plus with BOSE and hidden Dension Bluetooth, Multi-changer, Heated Front Seats, Bi-Xenons, FE Wheels, Phone Prep with Nokia 6210, Detachable Towbar, Rear Blinds, S8 plate but no other optional extras 1st Place Winner - A8Parts Annual UK Meet 2018 1st Place Winner - A8-Freunde Annual German Meet 2018 2nd Place Winner - A8-Freunde Annual German Meet 2019 2002 A8L D2 with a factory fitted S8 engine and drivetrain - "Evergreen" - Irish Green Pearl (TBC) - magnolia leather seats with magnolia door cards/door trims, magnolia leather head-lining, extended leather pack 3 (dark green leather dash, upper door cards, steering wheel, lower dash, centre tunnel and rear parcel shelf), factory black external trim (in lieu of chrome), self-levelling suspension, Servotronic, Brembo brakes, "gullideckel" / "man-hole cover" / "pie-plate" 8Jx18 polished 10-hole design wheels typically seen on the W12, Park Distance Control, heated windscreen, multifunction steering wheel, Vavona burl (burr-walnut) wood inserts with cream/magnolia door switch trims, phone preparation to the front with Nokia 6091 phone, phone preparation to the rear with Nokia 6091 phone on the central rear console, third phone preparation in the rear centre console, rear blinds, rear headrest release feature, rear electric heated seats with lumbar and recline function (the rear passenger seat has the facility to move the front passenger seat forward), BOSE audio, Rear Screen Entertainment (RSE) with dual factory fitted Alpine screens, integrated DVD player (under the centre of the rear bench with 4 DVD storage slots) and two remote controls (the controls and inputs for the RSE are in the rear centre console and the screens can operate independently of each other,) factory supplied leather headrest covers to hide the rear screens, rear vanity mirrors (standard A8L), dark green rear wedge footrests with cream piping, front passenger memory seat, dark green floor carpeting and mats – piped in cream, rear slumber pillows for the headrests, integrated fridge with integrated tumblers inside the rear centre headrest bar compartment, solar roof, auto-dimming interior and exterior mirrors, factory driver’s seat fire extinguisher, tire pressure monitoring system, first aid kit, 12 V socket in the boot, TRACKER, derestricted – top speed is 155mph plus 2007 A6 Allroad C6 3.0TDI Quattro - Highland Green (Audi Exclusive Colour) - Cream leather interior with Wood, Advanced MMI, Keyless, Bose, Advanced PDC, Sunroof, Heated Memory Seats, Adaptive Xenons, Adaptive Air Suspension, Servotronic Previous (went to good homes): 2002 A8 D2 2.8 Quattro Sport - "Big Red" - Tornado Red (Special Order) - Twist Interior, PDC, Passenger Memory Seats, Symphony II with BOSE, Heated Front Seats, Bi-Xenons, Auto-dimming Mirrors, 20" FE Wheels, Servotronic Steering 2002 A8 D2 2.8 Quattro Sport - Aqua Blue Pearl - Twist Interior, PDC, Sat Nav Plus with BOSE, Multi-changer, Heated Front Seats, Bi-Xenons, Auto-dimming Mirrors, Avus Wheels |
#39
NLA is 'No Longer Available'. Sadly its becoming a common occurrence for D2-specific parts like hoses, trim etc. Even the little plastic arm for the headlight levelling now too - luckily yours is still serviceable.
Goran's car is a LHD manual, so if its leaking gear oil from the cooler lines there's a 50/50 chance the hose which is leaking is not available to buy any more. Being a manual, there aren't any secondhand either like there are for the autos. That would be a problem, were I not doing a RHD manual conversion in October, however since those hoses aren't available I will be developing an alternative solution ![]() |
#40
