Go Back   A8 Parts Forum > A8 D4 > D4 - Body and Exterior
D4 - Body and Exterior Bumpers, bonnets, glass, trims - Everything outside
Old 5th October 2017, 08:25 PM
GlynH GlynH is offline
Default Post a picture of your rear end...
...showing the TDi badge above the Quattro badge on the boot of a 2011 4.2 TDi if you can please!
There...I bet that elicits a response!
Reason being a previous owner of my car stuck a cheap, tacky & wonky TFSi badge above the Quattro on the right hand side of the boot.
My OCD can't cope with that so I've already removed it so I have to badge it as it left the factory and as I've already spent £19.61 on a TDi badge I'm hoping it never had the 4.2 logo as well!
Just wondered the placement of the TDi badging...
Thanks & kind regards,
-=Glyn=-
Old 5th October 2017, 08:58 PM
Sorry I cant help, mine is attached to the side of my metal shelving - just left the rings on the car
Old 5th October 2017, 09:47 PM
Conquistador's Avatar
There will be some exact dimensions and positioning somewhere in a workshop manual I'm sure, but for now you can't get more accurate than the press picture...
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 5th October 2017, 10:33 PM
Here it is
Old 6th October 2017, 05:39 PM
Joe2.0E Joe2.0E is offline
Photo attached if you still need one
Old 8th October 2017, 06:39 AM
Thank you very much for taking the time to reply Guys!
Looks like a 4mm gap between the existing Quattro badge and the new TDi one with the i finishing flush with the right hand side of the Quattro badge.
Looks like I have bigger things to worry about as I've noticed oil leaking from the rear sports differential these last couple of days...
-=Glyn=-
Old 8th October 2017, 07:48 AM
-=Glyn=-
Depends where it is leaking from, having had the sensors replaced mine dropped some oil, turns out it was just slightly overfilled and was coming from a breather hole...... stopped naturally.
Old 8th October 2017, 07:13 PM
On mine, It looks more like the Left edge of the "T" is flush with the left edge of the "Quattro" badge. The outer edge of the "I" seems to be slightly further to the right of the edge if the "Quattro" badge.
Sounds very pedantic but it may bother some folks.
Old 19th October 2017, 11:32 AM
Oh it would bother me and now I'm in a quandary...
-=Glyn=-
