Old 10th November 2017, 06:34 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default MMI Panel & Display
What would cause the MMI panel to be dead and the screen not to pop up?
Fuses appear ok and MOST loop is complete.
[center]
06 3.0TDI Quattro:
Options:
Old 10th November 2017, 06:50 PM
I had this with increasing frequency, mostly at start up, when my battery was on its way out. Maybe that?
Old 10th November 2017, 06:53 PM
ScottD3's Avatar
Battery is good.
[center]
06 3.0TDI Quattro:
Options:
Old 10th November 2017, 06:55 PM
MMI buttons?
Matt
Old 10th November 2017, 07:00 PM
Stuck buttons on the MMI control panel can cause this.
Old 10th November 2017, 07:04 PM
ScottD3's Avatar
The buttons all seem fine, nothing stuck.
What controls the mmi panel and display?
Cause they work with the ignition off.
[center]
06 3.0TDI Quattro:
Options:
Old 10th November 2017, 07:22 PM
ScottD3's Avatar
So I'm clutching at straws but would a faulty/broken onboard power supply control unit cause it to pack up but if it did, what else would break?
[center]
06 3.0TDI Quattro:
Options:
Old 10th November 2017, 11:41 PM
47p2's Avatar
47p2 47p2 is offline
Disconnect the battery for 15 minutes then reconnect it again
Nite Blue 3.0L SE Quattro
Old 14th November 2017, 08:04 AM
ScottD3's Avatar
Fixed it.
Unplug the head and gateway. Plugged it back in.
Thank you.
[center]
06 3.0TDI Quattro:
Options:
