IT, AV and other Tech All computing, home cinema and technology that isnt car related |
#351
How useful! I got a Vega 56 before OCUK sold out so I'll have to get an emulator too
![]() I can't find anyone else selling the Vega even close to OCUK's price. Best so far is CCL at £487 ![]() Ooh £428 from Aria on special offer. Last edited by MikkiJayne; 23rd November 2017 at 11:04 AM. |
#352
Yes I have emulator, my other AMD does not run correctly either without anything connected but runs fine with emulator but I cannot get max out of Vega without display. The thing is that I still need to see what's on the screen to do AMD Wattman adjustments so need to connect actual display or do remote login anyway at some point. If I have emulator and actual display connected it still drops performance when I disconnect actual display. Using Remote desktop or TeamWiewer I can never get full performance in the first place. I have also tried connecting display to other cards and using different HDMI/DisplayPort connections but without much success. If I could write the batch file to do all the settings on PC startup and then start the miner with just the emulator connected and then periodically check if miner has not frozen and restart it if required it might work but that's a bit above my skills so I have just settled for 1700H/s for now.
#353
Also 1 of the RX580 that I pre-ordered from Amazon in July was finally delivered to me ( from France ) and at very discounted price as well. Amazon only charges card when item is actually shipped not like ebyuer who happily took my money straight away for pre-order and then refunded couple of weeks later saying that they could not get any stock.
#354
I think i might have cracked running Vega.
1. At the start I connected it to the main PCI-e slot where you would put your GPU if you only had one and once I was satisfied that it was running I added other 2 cards. When I was trying to troubleshoot performance problems switching display on/off I just moved display connection to another card.I have now moved Vega to another slot and one of RX 480cards to primary slot and that now has display connected. 2. Before I was running all batch files for different cards from the same miner file, I have now made copies of miner in different folders and each batch file for each card runs from a separate file. I am not sure which of this has made the difference or if it will last but for now I can get 1.9K H/s from Vega and I can use TeamViewer without causing ill effects.
#355
Nice work
![]() I think I might still stick with nVidia cards for my next GPU rig; they're just so much less hassle. Have you got your D3 yet Ainars? My D3 arrived a few days ago. Tried it on NiceHash initially but, as expected, profitability was poor (just about managing 1mBTC/day). I'm trying it on poolmining.org right now. I don't expect the earnings to be any higher but it'll be earning Dash, the price of which I'm expecting/hoping will rise in line with mining difficulty.
#356
Ainars have you seen any stability issues with the Vega? I seem to have managed to make the only Vega rig which can't mine Cryptonight
![]() I did manage to get both cards running 2KH/s with Cast-XMR following that guide you posted, but only for 60 seconds then they locked up again ![]() Most vexing! Going to try one on a Windows 7 board later... |
#357
I have not even tried NiceHash miner. I am also on Windows 10 with blockchain driver and XMR miner. It has had some lockups but nothing like 60 sec, I think longest it's been running without issues was 4 days. I have not noticed if they still consume power when locked up. I am not sure if it will work on windows 7, requirements show Windows 8/10.
Have you tried at stock settings, not overclocked to see if they lock up, also 1 card at the time, switch cables, connectors. What memory speed are you running on your cards? Mine only works up to 975MHz, guide shows up to 990. You can also try saving 2 copies of miner either renaming it or having in 2 separate folders and running each card from separate file. After I made adjustments yesterday on mine it's been running OK so far It's definitely not a set and forget solution as the driver is beta and miner is also still in development. Even other AMD cards with supported drivers and other miners are not that stable. nVidia is much better in that regard but more expensive and slower returns. It all depends if you have time or want to spend time monitoring or you just want to set it up once and leave it alone. I have TeamViewer installed on all PC's and phone so I just check in every now and again and restart if required.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 25th November 2017 at 10:52 AM. |
#358
#359
Vega still running fine since the changes yesterday, the cheap RX 580 from Amazon added to my AMD rig so that's another £42/month with less than £10 extra in electricity costs, - not bad for a card that Amazon only charged me £102 for. D3 still not shipped but received $125 coupon from Bitmain
![]() There are couple of custom design Vegas out there that should have better cooling/less noise but will probably be expensive: https://hothardware.com/news/powerco...ocked-preorder https://hothardware.com/news/xfx-off...double-edition Baikal Giant X10 profit dropping as expected, still on top for now but will probably go down a lot by the end of year. S9 earning well with L3+ is not bad and at selected times better than S9. Dash and Ether prices have gone up but Nicehash mining payouts for both while have increased a bit does not reflect price increase, Litecoin have done very well today as well - +13%
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 25th November 2017 at 08:00 PM. |
#360
