Old 23rd July 2010, 09:57 AM
ulfilias ulfilias is offline
Default Strong-flex Poly Bushes ???
Hi There,
Been looking at my suspension and came across these. Can be picked up off ebay, but the main web site is below. Don't know if anyone has used them or has any info, but thought there may be interest
http://www.strong-flex.eu/index.php?...chk=1&Itemid=1
Old 23rd July 2010, 11:32 AM
A quick 101 on suspension components (or any components for that matter).
Using EKTA chase down the component you want then start to delve because it's a good chance given the age of our D2s that there has been some changes.............
In this case a bush for the front lower rear control arm.
Once you have it's number double click on it and up will come:
You can see the part was replace in 2005. Double click on that number:
and you'll see it was replace in 2007 . Double click that number....
And finally you'll find the latest part no.
Now go and check what models these parts will fit..
The first number fits....
The second number fits more!
However........
The third number is more specific and the reason may be that the control arm has changed through time as well.
The moral is to check what you have before buying components on the after market. If it's made to fit an A4 and it's the same part number that is fitted to your 8 then it should fit. There are UK based Poly Bush manufactures that do full kits for A4s that may fit your 8. Just check the part numbers of the components fitted first.
ID:	1240   Click image for larger version
ID:	1241   Click image for larger version
ID:	1242   Click image for larger version
ID:	1243   Click image for larger version
ID:	1244   Click image for larger version
ID:	1245   Click image for larger version
ID:	1246   Click image for larger version
Old 23rd July 2010, 11:48 AM
You are indeed the Librarian who knows all!!
(ok who said hes soo wise because he's soo old!! )
Old 23rd July 2010, 11:50 AM
Ah.....You have a *MUCH* later version of the ETKA than me....*goes hunting for software*
Old 24th July 2010, 06:40 AM
B@fink B@fink is offline
weirdly i was just in an audi dealership getting my hub bolt to swap my cv boot and checked the current price of that bush...they're 31 quid + VAT near as make no odds.
