D3 - Common Faults Quick links to all known common faults and their solutions |
ok, bit of a write up on the micro switch repair.
I hope it is of some help to people. Any questions feel free to ask if I have not covered something you want to know about. first you obviously need to remove the door card, there are guides out there so I wont go over that one again. next you need to pop out the 2 large rubber gromits and buzz down the window till the orange plastic is visable with the torx screws. ( need to plug the door card back in for this to work) remove both screws and leave the window runners where they are or you will struggle to get the inner panel off without breaking something. Next support the window in its closedl position somehow, suction cups didnt work for me so used tape. next remove 12 torx screws from the inner panel, the 3 x8mm nuts that hold the soft close motor in place. Push the 2 rubber gromits that both bowden cables are in through the panel. remove the soft close motor and unclip from the back the plastic connector and pop off the ball end of the bowden cable ( this is obvious when you se it) make sure all electrical connectors are popped off and any securing points on the panel for them are removed. once all this is done you can take the inner panel off! You have 2 x8mm multipoint (NOT TORX) screws you need to remove to get the latch out. once they are off you have to remove a plastic cover, 2 points on it are sprung clipped to the main body, a small flathead will pry it open and the thrid point is a pointless plastic screw that i just murdered as it wasnt coming out for me, didnt appear to be needed on re-fit so i dont give a monkeys! again dis connect any electrical connector and at the top of the latch is a separate connector that needs to come off, it has a bowden cable attached that goes up into the door for the manual key ( so you can lock and unlock the car if battery dead etc), just pop that off and the exterior door handle rod and you are good to get the latch on the bench. I got the dremel out and cut out the section need for the soft close microswitch, gave it a push where those 2 small holes are and when it was in a position to do so pulled it out, on the other side of the micro switch its held in by a bit of sprung plastic so anything thin enough to wedge it should work ok. cut the wires, offer up the new switch in same orientation as the old and seat it untill you hear it press/click, for my switch it needs to be pressed when fitted, it is on the release of the switch bar that my motor kicks in, so for me the connections were the right and middle spade.if you put a meter on, you want an open loop when the door lock is fully open, and you want it to make the electrical connection when the lock makes the first click as when the soft close should normally kick in, and it should keep that connection when door lock is fully closed. so get the switch postion sorted, bit of solder and i used hot glue to hold everything in place. all back on my motor and so far so good. not sure how long these maplin (product code N96AQ) £2.29 micro switchs will last but no issue replacing them again if and when the do go.
2006 S8 5.2 V10 |
Thanks for the write up - excellent!
I've added the link for this thread to the Common Faults stuck thread at the top of this section so that it can be easily found ![]()
Thank you.
I know this is one of those pain in the bum things we all have, and annoyingly no proper write up on it. Not saying mine is great but it should at least get guys heading in the right direction to sort the problem.
2006 S8 5.2 V10 |
Thanks for the write up Rick, much appreciated. It will become a popular reference I don't doubt
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
No problem.
I plan on doing a video when I do the passenger side which will hopefully help as well.
2006 S8 5.2 V10 |
Hope its gonna be a BBC documentary standard as my passenger door needs doing too
Del ![]() |
Present cars Daily driver: BMW e65 730d Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry. ![]() |
Sadly I no longer own a Maplin catalogue, but looking at the pictures you need a short lever SPDT microswitch, take your pick from here....
https://cpc.farnell.com/c/microswitc...-microswitches At 50 pence a pop, maybe you could order a couple of options, but the yare mostly interchangeable ![]() |
