Old 2nd February 2018, 02:28 PM
Regulus Regulus is offline
Default vcds scan after service
My S8 was serviced by Lecab, Audi Karlstad the 31st last month.
I made it home, with the engine oil lamp on and the rpm needle was dead.
Today I ran a scan with vcds to try see what it would tell me.
The engine oil lamp and the rpm needle worked today, so I took it for a drive. About 400m from my home the car made a few engine brakes, or I think it did. Then it died. So now the car is on it's way back to Lecab with roadside assistance.
Here is my auto scan before the road failure.
VCDS Mobile 0.4411.0.4
Chassis Type:4D
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
Address 01: Engine Labels: None
Part No SW: 4D0 907 557 N
Component: 4.2L V8/4V MOTR AT D01
Coding: 04373
Shop #: WSC 02324 000
VCID: 3731B8DF19C18580022971845-4B1E
12 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
01183 - Warning Light for Catalyst Monitoring (K72)
31-00 - Open or Short to Ground
16705 - Engine Speed Sensor (G28)
P0321 - 35-10 - Implausible Signal - Intermittent
17917 - Idle Control Valve (N71)
P1509 - 35-10 - Electrical Malfunction - Intermittent
17817 - EVAP Purge Valve (N80)
P1409 - 35-10 - Electrical Malfunction - Intermittent
17609 - Fuel Injector for Cylinder 1 (N30)
P1201 - 35-10 - Electrical Malfunction - Intermittent
17613 - Fuel Injector for Cylinder 5 (N83)
P1205 - 35-10 - Electrical Malfunction - Intermittent
17612 - Fuel Injector for Cylinder 4 (N33)
P1204 - 35-10 - Electrical Malfunction - Intermittent
17616 - Fuel Injector for Cylinder 8 (N86)
P1208 - 35-10 - Electrical Malfunction - Intermittent
17919 - Intake Manifold Valve (N156)
P1511 - 35-10 - Electrical Malfunction - Intermittent
16944 - System Voltage
P0560 - 35-10 - Malfunction - Intermittent
17968 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
P1560 - 35-10 - -) - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No SW: 4D0 907 389
Component: ABS/FDR Allrad D3202
Shop #: WSC 00000 000
VCID: EC9BD7B390077658BF3B36004-51CE
1 Fault Found:
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
Address 08: Auto HVAC Labels: None
Part No SW: 4D0 820 043 K
Component: D2-KLIMAVOLLAUTOMAT D05
Coding: 00080
VCID: 240B7F93B857FE18B76B9EA0C-2568
4 Faults Found:
00715 - Rear Footwell Vent Positioning Motor (V112)
41-10 - Blocked or No Voltage - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
41-00 - Blocked or No Voltage
00734 - Potentiometer in Central Vent (G142)
30-10 - Open or Short to Plus - Intermittent
01592 - Air Quality Sensor (G238)
57-10 - Electric Circuit Failure - Intermittent
Address 15: Airbags Labels: 4D0-959-655-AI7.lbl
Part No SW: 4D0 959 655 H
Component: Airbag 7 Audi 050C
Coding: 00225
VCID: 3731B8DF19C18580022971845-5118
No fault codes found.
Address 17: Instruments Labels: 4D0-919-033-MYW.lbl
Part No SW: 4D0 919 033 AF
Component: D2-KOMBIINSTRUMENT D53
Coding: 00683
Shop #: WSC 19411 000
VCID: 68932BA304FFDA785B136AF00-508A
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No SW: 8L0 862 257 N
Component: CV-Pump D06
Coding: 13130
VCID: 40C3D3034C0FC238B383D2108-4EEA
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No SW: 8L0 951 173
Component: Innenraumueberw. D04
Coding: 00001
VCID: EE9FDDBBA61B8448914F2C382-4AA4
1 Fault Found:
01378 - Ultra Sonic Sensor for Alarm System; Right (G171)
27-10 - Implausible Signal - Intermittent
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No SW: 4B0 907 357
Component: LEUCHTWEITEREGLER D001
Coding: 00008
VCID: E58DA29773ED4710E0F5CBACF-5160
1 Fault Found:
00776 - Level Control System Sensor; Left Front (G78)
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No SW: 4B0 035 186 E
Component: Radio 0001
Coding: 00207
Shop #: WSC 02325 000
VCID: 2207798BA243F028C55768886-4B00
1 Fault Found:
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
Address 76: Park Assist Labels: 4B0-919-283.lbl
Part No SW: 4B0 919 283
Component: arkingsystem A8 RDW D17
Coding: 01108
VCID: E68FA59B8EEB4C08E9FFF4D8A-5216
2 Faults Found:
01543 - Parking Aid Warning Chime (H15)
01549 - Supply Voltage for Parking-Aid Sensor
29-00 - Short to Ground
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No SW: 4D0 927 156 BL
Component: AG5 01L 4.2l4V S8RdW D03
Coding: 00101
VCID: 74AB4FD348372E98E78BEE60C-51A8
1 Fault Found:
17087 - Brake Switch (F)
P0703 - 35-00 - Electrical Malfunction
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
Old 2nd February 2018, 06:06 PM
Wow Its interesting that most of the modules simply say 'electrical malfunction' rather than voltage too high or low. That might be a prefacelift thing though. ME7 in the facelifts is a little more verbose in its error messages.
I think the first things I would be looking at are the battery, alternator, and earth connections, particularly the earth strap from engine to body. Then probably monitor the battery voltage with a multimeter to see what its doing.
Some of those codes like the immobiliser and alarm are pretty normal. The open or short codes are likely caused by whatever is also triggering the electrical malfunction codes, in modules which aren't smart enough to detect a voltage issue.
Old 2nd February 2018, 07:02 PM
Thank you for the comment MJ. I haven't even considered the battery, and earth connections.
The mechanic claimed that the wiring to the oil pressure sensor is damaged. Which they have in part replaced at an earlier occasion (about half a year ago).
Is it normal that one can do a full auto scan, but other specific scans throw timeout errors?
I didn't get the engine scans to respond. Same with the Immobiliser even if I have scanned that part earlier.
The automatic box responded when I tested that.
Johannes
_________
A8 32V engine
Old 2nd February 2018, 07:25 PM
The oil pressure sensor wouldn't cause all those errors, even if it shorted out. I think there is probably something else going on too.
Its odd that you can scan the engine on an auto-scan but not on its own. I wouldn't expect that. It could be a symptom of a general electrical problem though.
Old 6th February 2018, 11:25 AM
I got an answer from Audi. The fuel pump 4D0298087B is broken
Repair cost 18000 SEK.
I asked them for an offer to fix the fuel pump, whatever the electrical fault is to the oil pressure sensor and fix that too.
And for an offer to change the belt cam with water pump etc.
This is going to make a dent in my bank account. But I still wish to repair this car.
I truly wish I lived not to far off from you MJ. I'd feel a lot better dropping the car off in your capable hands
Johannes
_________
A8 32V engine
Old 6th February 2018, 12:44 PM
Schedule a two week holiday in the UK.
Drive to MJ's and leave the car with her.
Hire a car and have a great time touring UK.
The total cost will probably be less than the stealers, and you will have had a holiday as well.
Old 6th February 2018, 03:58 PM
I don't know what 18000 SEK is but it sounds like a lot of Fjallraven jackets.
This the pump you need LINKY, It can be fitted into your pump unit and can be done at home with basic tools, and you can get off your face on petrol fumes
If that 18000 is just for the (updated) pump unit then the quote for the cam belt will be horrendous.
Old 6th February 2018, 04:03 PM
18000 Swedish Krona? According to google that's a shade over £1600 GBP today.
That sounds pricey given the ebay part is £120!
Old 6th February 2018, 04:11 PM
Yeah it's about double what Audi want here. The pump is only 120 ish but the pump unit is 800, Audi discontinued the pump unit as it has a mod and the pump is not available from them, so if you want it from Audi you have to buy the whole modded pump unit.
Old 6th February 2018, 04:26 PM
That is correct, just over £1600 for the pump with fault checking? and replacement.
Is that really the part Dezzy? The part number doesn't check. 4D0298087B
But from what I could find, the part is expensive.
https://www.online-teile.com/volkswa...inbausatz.html
And I am not about to take the fuel tank apart just to do the job myself. I don't have a nice garage, and it's cold and icy outdoors
-7 degrees C or 19.5 degrees F
Johannes
_________
A8 32V engine
