Go Back   A8 Parts Forum > General Natter > House and Home DIY
House and Home DIY Everything at home. Building, Renovating, DIY, green initiatives, mowing the lawn. Anything goes
Old 6th April 2018, 09:46 PM
I run a nuheat thermal store, which works brilliantly, albeit a departure from typical domestic installs.
It basically a giant hot water cyclinder, but full of central heating water.
Boiler runs on a standard thermostat to keep it topped up to temp as required. Also has inputs for green technologies, solar panels etc.
Then, your heating just draws off the hot water as required via the normal CH pumps.
HW is mains pressure, but heated on demand via coils inside the thermalstore, giving instant, endless hot water.
Much more efficient for dribbling out bits of heat here and there as the boiler only need kick in occasionally to blast things back up to temp. Designed with underfloor heating in mind, but equally useful for rads.
I bought mine second hand, installed it about 6/7 years ago now and its been great.
