Old 13th April 2018, 05:18 PM
Stunning work MJ
Aplogies in advance if this is nonsense, I am well fluent in it...and I understand it is probably Vera's choice in this case, but if this was my car and there was even the slightest hint that LPG could have contributed in some way to this, I would'nt be reinstalling it in the new engine. I frequent many car based forums and see quite a few problems related to LPG. However I guess the biggest question I have is if LPG is so great why are major manufacturers not offering it as an option on new vehicles, particularly in these times when diesel (rightly IMHO) and petrol is getting bad press.
Just the thoughts of a rambling Scotsman
Old 13th April 2018, 08:01 PM
Stunning work MJ
I've had my D2 running on LPG since November 2013. To me there has only been two downsides, the time it takes to fill the tank and the lack of petrol stations that actually sell it. Other than that, the only time the LPG has stopped running is when it detected a fault with one of the ignition coils.
From a manufacturers viewpoint, I suspect it would be to do with where to locate the actual tank. Mine is a 125 litre tank running across the back of the boot. You could fit a smaller capacity toroidal one in the spare wheel well, but then you lose that space. You would also need a small petrol tank since the engine starts on petrol and switches to LPG when it reaches a certain temperature. That would mean having two fuel tank instruments. The LPG filler is also non-standard so you need different adaptors depending on where you travel e.g. I have one for buying my LPG over the border in Ireland.
Lastly, from the back pocket perspective, best thing I've ever done to the car. Some very rough figures. Until the time I got the LPG conversion done, I had covered just shy of 5,000 miles at a cost of £1,977. From the conversion and for a cost of £1,965, I travelled 18 mile short of 10,000.
Old 13th April 2018, 08:55 PM
Apologies in advance if this is nonsense
Its a valid question. While I can't say what has caused the oil thirst, I do not believe the LPG is to blame. I've done some digging and I don't think the injector adapters are upsetting the spray pattern. Its not uncommon for tuners to use similar adapters when fitting different models of injectors. Plenty of cars run on LPG just fine, and Vauxhall did sell some models brand new with LPG, albeit dealer-fitted, but they still had a warranty.
That said, the engine will be run-in solely on petrol for at least the first 8-10K Km. We'll be able to ensure its behaving the same as mine before it gets it's first sniff of LPG
Old 13th April 2018, 09:11 PM
A more successful day today, albeit still with considerable upside-down backwards spine bending!
This is where the clutch hose screws in to the master cylinder It took about an hour of wiggling and tweaking to get the union at just the right angle for it to catch the thread.
Here it is from the engine bay. I reattached the slave cylinder and pressure bled it while the engine was out.
I finished off the paint too. Completely forgot to get pics of it in primer, but basically I've feathered the edges of each paint stage to blend it in.
Some colour on
Then clearcoat / lacquer
Complete
I'm pleased with the work, but rather disappointed with the colour match. The aerosol ended up having rather more purple in it than the original paint which in comparison is more green. If it was the same colour the repair would be nearly invisible. As it is, its acceptable considering you can't see it without removing parts.
Engine ready to go back in
And bolted back in the car
Vera was able to stay long enough this evening to see the marriage of car and new engine
ID:	18428   Click image for larger version
ID:	18429   Click image for larger version
ID:	18430   Click image for larger version
ID:	18431   Click image for larger version
ID:	18432   Click image for larger version
ID:	18433   Click image for larger version
ID:	18434   Click image for larger version
Old 14th April 2018, 05:32 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
It's not out of the realm of manufacturers to be able to offer both LPG/Petrol.
Nissan/Toyota/Mitsubishi all offered industrial versions of their car engines as dual fuel.
Forklifts traditionally ran as petrol engines with a LPG vaporiser converting the liquid form in to a vapour and dumping it in to the intake manifold.
A toggle switch on the dash switched between petrol and lpg.
I still have a few on the hire fleet that run this system.
More modern trucks run a system very similar to Vera's D2 setup with the LPG injected in to the fuel injection port (or as is the case nowadays, in direct replacement to the fuel injectors running as LPG only)
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 14th April 2018, 08:18 AM
I know we are all a bit OCD on this forum MJ but as you have tp prize the covers off covering the turret and then still have a few pipes etc in the way along with the general road dirt I think its going to be hard to detect the difference in paint shade!!
Its interesting that Vera's paintwork is clear coated all the way inside the engine bay. Mine certainly isnt and, as I remember you showing me on Dean's red-mobile, his was half and half!
Old 14th April 2018, 12:32 PM
My S8 (my last work car...) has cost me around £18k in fuel over the first three years I had it: My current work car cost me around £800 in total over the same duration, covering roughly the same mileage ( no zeros missing...)
Old 14th April 2018, 02:00 PM
ive seen this crack on another members car when he had his engine out, his name escapes me at the moment,
great work MJ
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 14th April 2018, 02:25 PM
Epic thread.
Any idea as to why the seam at the turret has cracked and needed welding?
Old 14th April 2018, 02:53 PM
Epic thread.
Epic thread indeed. As to your question, you need to go back to page 4, post 36 for precise details:
http://forum.a8parts.co.uk/showpost....2&postcount=36
No skipping any more posts There will be an exam at the end.
