Every time I start the car I can feel the engine shaking, not violently but definitely noticeable. Quite embarrassing when passengers point it out. It does it on both petrol and LPG and the rev needle moves up and down just slightly, my old S8 never did this. The revs were always constant and the engine smooth. It only does it for the first 5 mins, after it warms up it is fine. Any ideas what it could be? Ben checked the cambelt the other day at Audi's in the park and said it had been put on wrong, could this contribute to it? I'm starting to feel I am just unlucky when it comes to cars now. If this is going to cost a lot I'm going to go shove it of a f\88in cliff
![]() Vag Com says this: Address 01: Engine Labels: 4D0-907-560-AVP.lbl Control Module Part Number: 4D0 907 558 J Component and/or Version: 4.2L V8/5V G 0004 Software Coding: 05753 Work Shop Code: WSC 00460 Additional Info: WAUZZZ4DZ1N003922 AUZ7Z0Y1489941 4 Faults Found: 17538 - Fuel Trim; Bank 2 (Mult): System too Lean P1130 - 35-00 - - 17536 - Fuel Trim; Bank 1 (Mult): System too Lean P1128 - 35-00 - - 18058 - Powertrain Data Bus: Missing Message from Instrument Cluster P1650 - 35-10 - - - Intermittent 16955 - Brake Switch (F): Implausible Signal P0571 - 35-10 - - - Intermittent Tuesday,10,August,2010,20:57:13:36799 VCDS Version: Release 908.1
check your MAF sensor and hoses for operation / leaks Amar sounds like it might be an issue. The only other thing im wondering is that if the cam belt wasn't done quite right as Ben said then maybe its contributing to the lumpy running?
If its running lean then dont leave things too long and use super unleaded at all times for now
There are two ways to do a cambelt change:
1) You have the correct Audi tools, you lock the camshafts and crankshaft in the correct position, remove old belt and fit new one and tension with everything locked up - This is the proper way to do it. 2) You cut corners by marking with chalk on the pulleys what position they were in when you take the belt off, and simply try and line it up when you put it back on. This is the quickest way to do it, and sadly a lot of garages will do this - even Audi ones ! - This leaves the belt potentially a little out of sync which the engine ECU can (and does) compensate for. I'm pretty sure you can see this is measuring blocks with Vagcom. I guess if you use method 2 too many times though, it would lead to unrecoverable discrepancies in the timing and it would be a problem. That said, I'd expect it to be a constant problem, not something that goes away after 5 mins. I had rough running on that engine when I first got it because the garage had left the cats off, and it had no lambdas so it got no signal and ran rough as it didnt know what its emmisions were. I wonder if you just have a simple problem on a lambda probe? The MAF is worth checking too... It cant be anything serious, it'll just be some mis-information that the ECU is getting from somewhere... oh.... and dont you threaten to push her off a cliff... Ggggrrrr.. ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
The timing belt's definately not helpoing Amar and could explain why it's worse when cold as the valve timing is altered during warm up, but also need to look for, as suggested, duff air mass and air leaks.
keep ya chin up bud and she'll run fine in the end! |
Neil, Its running V Power, that's all I have used in my S8 and this, I think the maf has been replaced recently, looks like an Audi genuine part to. Leaves the air leaks and cam belt now.
Thanks Ben, so its altered during warm up, that makes sense to. I think I will let you give it a very thorough health check when your back from Germany and get any issues that need doing sorted after pay day. Cambelt alone is £500 though and I would want to get the waterpump done and with it being a genuine part will need to add another £100 or so on to that. FFS ![]()
2009 Audi RS 6 Saloon V10 - 420mm Ceramics, Keyless, Soft Close, Adaptive Cruise, Glass Sunroof, Blinds, Twin Pane & UV, Freeview & DAB, High Beam Assist, MTM bits, Audi Exclusive Bits, MRC, Milltek, GYEF1 ASY2's, Bluetooth streaming music to AMI mod - 753 PS/1021 NM 2016 Audi S3 Saloon, Sepang, S-Tronic - B&O, Tech Pack etc... Company Car 1995 Audi A8 4.2 V8 quattro Sport - Bose, Solar, Blinds Last edited by Singh; 11th August 2010 at 11:21 AM. |
Ian, missed your post. The lambdas aren't showing any faults. Only get about 17mpg in this though whereas on the same journey would get 19 from my S8 which had fresh lambdas.
17 is about right - you lose about 10% power/mpg on LPG ?
If you are seeing 17 on petrol though, then something isnt right....
About 17 on petrol...
I bow down to Bens expertise in this area.... I was seeing about 16 - 17 mpg average on LPG on a long run, with 19 - 20 on petrol on a long run (I only ever did long motorway runs). I guess if 17 on petrol is a mix of driving types its probably no worse than when I had it....
I didnt notice any vibration though.... ![]() I'd really like to know what Ben finds as its never missed a beat with me, although I guess I didnt go straight from another S8 into this one, so dont maybe have the direct comparison you do....
That's with mixed driving, 65% motorway and 25% town. I hardly every push the car, get 20.5 on the motorway on a long run, used to get 22.5 in the S8.
As soon as you start it, the shaking is quite obvious. I was so embarrassed when a friend pointed it out and had my fingers crossed he wouldn't notice as he knows how much I paid for it. Boy was my face red when he said 'why the hells it shaking like that for' Only does it on idle.
