Old 28th April 2018, 11:06 AM
Not so certain about the Skoda ones as I've not got my hands on them yet
Well they have arrived but are a complete waste of time, because:
1. The connector is NOT the same as the D2; it looks similar but is significantly larger so does not fit.
2. The unit is more "low profile" then the D2 or Focus units, probably one reason why the Russians raised it so much to clear the wiper arms.
3. The jet squirts more upwards than the Focus, and does not appear to be adjustable. (ref Russians again)
4. The unit is smaller so does not clip into the D2 mounting slot. (ditto)
But regarding the Focus ones:
A quick rummage later and I found the originals I had replaced (why do I still have them? )
And one answer is that I also kept the washer/grommet that helped seal them tightly to the Focus bonnet.
The new ones didn't come with those, but moving them across makes the fitting into the D2 scuttle much more secure.
Just need some decent weather now to go out, connect and test them and if OK connect up the heating elements.
