Old 2nd May 2018, 05:20 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
My word. You put us hobby bodgers and plenty of professionals to real shame!
I agree!!!
I know I'm fussy about wiring etc but MJ takes this to a professional level!
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 2nd May 2018, 04:47 PM
johnny_quattro's Avatar
Thumbs up
Well, I doff my cap to you MJ for the immaculate write-up, the attention to detail, and the quality photo accompaniments to this thread. I get the overriding impression that there's always a fix for whatever comes your way.
With respect to the amp, I remember that Phoenix Gold one very well from back in the day - it was THE reference amp to have. Infiniti Kappa subs were experienced in a show BMW when I attended the IASCA finals in Dallas. All great quality stuff there and a very neat install. I'm in the same boat as Richy/Ricky D insofar as my old A8 had the ski hatch but my newer A8L doesn't. Thanks Andrew (HPsauce) for the link in this thread, which I will read with interest.
Like many others on this thread, I look forward to the day when I can get booked in for some MJ fettling although I suspect that won't be any time soon - you've set a massively high standard with the quality of your work and we can all see that from the photos/mini storyline.
I will continue to watch this thread although I know that all good things come to an end eventually.
Old 2nd May 2018, 08:11 PM
MJ I really enjoy the quality of your work and the quality of your posts. It is gratifying to see you bring one of these lovely machines back to a fine state. And your brilliant efforts in recording and describing are icing on the cake. Thank you.
Old 2nd May 2018, 08:42 PM
Djinny's Avatar
Djinny Djinny is offline
So it is. There's comfort in that also in regards to future mysteries.
S8 FL manual drive, 11/1999, pelican blue, customized by the Quattro GmbH, KAW 60/40, Supersport silencer, 19" from the S8 D3.
LPG & 385mm front brakes (D3).
Old 2nd May 2018, 08:51 PM
Thanks guys
Mending trim tonight. Started with the handbrake cover - as usual the stupid plastic doodad had broken off. This is another fine candidate for some re-engineering when I have more time, but in this case I'm going to repair it with a donor piece.
Drill the heads off the rivets.
Very gently, separate the wood panel (actually wood laminated on to aluminium) from the plastic.
They're held in place by a dab of glue and some double sided tape, then the rivets are staked down.
I took the donor piece off a good walnut trim in the same fashion. I'll use the walnut piece for a re-engineering experiment later. Prepare the good plastic piece with some new tape
Stuck together and clamped in place for the glue to set
Mended
As usual, the mounting tab on the driver's side tunnel trim was broken. However, this being left hand drive I had no frame of reference to locate the tab so this one was slightly more challenging to repair. I had to assemble and disassemble it half a dozen times to get everything right.
Marked the level of the dash trim and the location of the bolt hole on some masking tape
Made a new bracket
Glued in place and clamped while the glue sets
To locate the hole for the bolt I reassembled it all and marked it through the hole in the dash trim
Drilled and snap nut installed
Right hand drive on the left, and left hand drive on the right for comparison
Installed back in the car
Dash back together
ID:	18715   Click image for larger version
ID:	18716   Click image for larger version
ID:	18717   Click image for larger version
ID:	18718   Click image for larger version
ID:	18719   Click image for larger version
ID:	18720   Click image for larger version
ID:	18721   Click image for larger version
ID:	18722   Click image for larger version
ID:	18723   Click image for larger version
ID:	18725   Click image for larger version
ID:	18726   Click image for larger version
ID:	18727   Click image for larger version
ID:	18728   Click image for larger version
Old 2nd May 2018, 09:32 PM
RS6's Avatar
RS6 RS6 is offline
Love seeing all this work MJ that car is well and truely sorted now!,
you are the Edd China of the A8 world!
I bet the owner of that S8 will be over the moon with it
I bet the first drive with the new engine will be lovely and smooth
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 2nd May 2018, 10:20 PM
Zip's Avatar
Zip Zip is offline
Question
Scuttle panel and windscreen washers tonight.
Pipes fixed in place
Hi Mikki....perhaps a silly question, but aren't those bulges on the supply hoses into the T-piece on the jet supposed to be pushed right into the rubber itself of the T-piece? I thought that's how they're held in...? I've pushed mine right in, as they were blowing off with any blockage in the jet.
Zip
Old 3rd May 2018, 01:01 AM
Zip
Likewise. Did that a few weeks ago for the MOT. That might also explain why the pipes always seemed to be a bit 'too short'. Maybe the small metal clips both hold them in place against the cover and prevent them 'blowing off'.
Old 3rd May 2018, 07:44 AM
Its a bizarre design but that is how they come from the factory. The bulge appears to be the stop for the rubber as opposed to the 'not popping out' arrangement you'd typically see on a hose. The metal clips should hold them in place so they can't move under pressure. The right angle piece where the flexible hose joins on to the scuttle has a cable tie round it to hold it to the plastic pipe, but that's the only one that does.
Old 3rd May 2018, 07:47 AM
That was popping off on mine recently so I fitted a new tighter one. All OK now, but it might all be coming off later today for the first "test fit" of my fan jets.
