Old 1st May 2018, 06:24 AM
Wheel bearing?
Another possibility of course, but that one was changed several years ago as the original whined a lot.
The first time I got all those lights on was not long after driving through a large puddle during the very wet winter and its been regular ever since.
I can almost predict when it's going to occur, the abs fault came up whilst I was scanning the car and the car was not even moving.
I wonder if there is a measuring block that can read each wheel speed sensor.
Given the choice would you go for a brand new third party sensor or a used 14 year old sensor from the forum sponsor (They are both the same price).
I am out of work from Friday, so will have plenty of time to work on the D3.
That reminds me, must finish CV. Working for the same company for 30 years means I didn't really have one.
Old 1st May 2018, 08:34 AM
I would use A8Parts, I've always had great service from them, and wouldn't have a problem using a used good sensor.
There is this new Bosch sensor,
https://www.ebay.co.uk/itm/302150530146?
Hopefully it's original and not a Chinese copy. Who knows!?!
Measuring Block 1 in ABS will display each wheel speed, not so useful in this case. Measuring Block 7 is Installation position, either invalid / ok / not ok. It would be interesting to see if yours displays invalid or not ok. Not ok would indicate a working sensor but inserted wrong with too much gap, bad bearing, axle tolerance (incorrect tyre size on that corner etc..). My guess now would be an invalid reading due to the puddle and the sensor may have water ingress.
All the best with CV, job, A8
Matt
Old 1st May 2018, 11:59 AM
Neither, I would try to check connectors and replace the cable on the old one first as it is usually the problem because conductors break inside cable from all the bending over time going over bumps so 14 year old is likely to get the same fault soon and aftermarket could be questionable quality.
Old 1st May 2018, 12:11 PM
I have replaced all of the twisted pairs of ABS wires to each sensor all of the way back to the ABS unit on my D3 A8L, this was due to the external casing getting brittle and cracking / breaking away in a number of places and the twisted pairs making random contact and setting of the beeps of doom on the dash
Old 2nd May 2018, 05:59 AM
I really hope is just a connection problem, with the connector itself. I drove the D3 50 miles yesterday with no problem at all, but I did not get stuck in low speed traffic which is what tends to trigger the fault, for example in a queue or sitting at traffic lights.
I had a water ingress problem with one of the air suspension electrical connections not long after getting the car, which caused all kinds of issues with the suspension. Since having that resolved it's been fine ever since.
Old 8th May 2018, 02:34 PM
Well as I am now unemployed, I took advantage of the time to remove the rear wheel and investigate the wheel speed sensor.
After disconnecting the wiring to the sensor, there was no apparent issues with either the car wiring connectors or the sensor itself.
I disconnected and reconnected the connector a few times and then clicked it back into place and went for a drive.
The drive was fine, but whilst sat in the car outside my house doing zero mph the fault recurred and has recurred again since.
I am assuming I checked the correct wheel (UK passenger side, rear).
Old 15th May 2018, 03:38 PM
I've been driving the D3 today, and no problem to report with the ABS until whilst sat idling outside my house doing 0mph the fault triggered.
Tomorrow I am going to hook up VCDS and connect to the ABS controller and look at measuring block 1 which should show me what all 4 wheel speed sensors are seeing and then start a log, and hopefully when the fault recurs I may catch something in the log.
I may even try going for a drive to see if that sensor is returning consistent readings compared to the other three sensors.
The attached picture is taken looking up at the sensor with the wiring disconnected, no sign of water ingress at this end.
Old 17th May 2018, 01:20 PM
Ok,
So today I've been out in the D3 with my laptop and did some logging with VCDS.
I've attached the results to this post, as you can see all is well and there are no problems at all for a while. All four wheel speed sensors read the same, and no faults until once again I was sat in the car not moving when the fault occurred. VCDS was logging at the time, so right down the end of the log you can see a blue section, just before that is when the fault occurred. The dark blue section is after the fault occurred, and you can see that the left rear sensor is no longer reporting data and the logged fault code cannot be cleared at this point.
Annoyingly you get kicked off the ABS controller once your road speed exceeds 20kmh.
Old 18th May 2018, 12:29 PM
im wondering if this is anything to do with a faulty brake switch hence it happening when you stop? relatively cheap one to replace if it could be that??
Old 18th May 2018, 06:05 PM
If the fault was occurring when moving I would say broken conductors in ABS sensor cable but since mostly happens when stationary I am leaning towards dry solder joint in ABS unit. Sitting in traffic etc results in heat buildup under bonnet, cracked solder joint expands and looses connection, start driving or leave car alone for a while it cools down joint contracts and makes contact again. Common problem for many cars, I think I have heard it happen on several D3's before. You can remove electrical part from pump and send it off for repair or you could have a go repairing it yourself, I did it once for friends Volvo, just cut it open, re-flow all big solder joints for plugs/solenoids and glue the cover back on.
