Old 4th July 2018, 06:42 PM
peiiider peiiider is offline
Default Whining noise in the cabin
So.. I have this kind of whining noise in the car.
It varies in frequency with the engine rpm and also seems to get less audible the more I push the throttle at a constant rpm.
It’s not LOUD, so if I listen to the radio I can’t hear it, but it’s still annoying..
If I turn AC off (push econ button) the noise disappears, so..
More likely to be the AC compressor itself or a pulley somewhere ?
Car in signature, ‘06 3,0tdi.
06 A8 3,0TDIq My daily driver and project...
97 A4 1,8Tq. Powered by a 4,2 from the '01 S6, full rollcage, FIA seats and 6-point harnesses, B5 RS4 KW Competition race suspension, B6 S4 brakes, 18" Toyo RS1 slicks, carbon fiber roof. V8 trackday racer
14 VW Caddy 1,6TDI from my employer..
(X)00 A8 2,8q, (X)97 A4 1,8Tq, (X)92 S4 2,2Tq, (X)92 80 2,3E
Old 4th July 2018, 08:35 PM
It's not the Mrs, is it?
Sorry.
Old 5th July 2018, 07:16 AM
mannyo mannyo is offline
in warm weather I've found the radiator fan runs at quiet high RPM with the AC on that can cause more noise in the cabin, but that is a constant sound that does not vary.
Manny
Past
Old 5th July 2018, 01:58 PM
Its a common problem - mine had had it since I bought it and is to do with HVAC fans/flaps which, apparently, requires a fair amount of work to replace. There is a thread which I contibuted to so ill see if I can find it.
Edit: This thread touches on it but it does refer to earlier posts on the subject.
http://forum.a8parts.co.uk/showthrea...=ghost+machine
Old 4th October 2018, 05:26 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Mine does this. Does my nut in. Was the last thing I thought of. I’d messed with everything before I switched the HVAC off and boom. Silence.
2007 Mini Cooper S R56
Old 4th October 2018, 05:47 PM
The commonest whining noise is the auxiliary coolant pump, but that stays on even if the HVAC is off so it's not that (for a change!).
Old 16th May 2019, 12:07 PM
Johnmed's Avatar
Did any of us ever manage to sort this? Still annoys me, (but then most things do).
Old 19th May 2019, 10:18 PM
Duff3103 Duff3103 is offline
do you have a video of the noise as i have a whining noise that goes with engine rpm also, i think its engine related ie turbo but can't find the location on the noise
Old 20th May 2019, 10:43 AM
Johnmed's Avatar
I’ve just tried to capture the noise. Cycling between HVAC Econ on/off.
Not really found a way yet, to get it to be picked up by my phone’s mic.
Old 20th May 2019, 12:39 PM
I'd guess at the magnetic clutch on the aircon compressor beginning to fail, when the econ button is pressed it doest try to engage, but when the aircon is required the magnetic clutch should cause the aircon pump/compressor to drive off the engine/belt. . .
