Old 13th February 2014, 08:48 PM
In a car with solar sunroof there is a hole in the tray for a sunroof wire.
Can I expect to have the same hole in the tray of a car without solar sunroof?
Your pic doesn't show Sergey - are you talking about the hole to retain the connector, or the one where the electrical wiring passes through from the contact to the underside of the panel?
This is how the wiring runs through when you've removed the upper rail:
Old 13th February 2014, 09:01 PM
The one where the electrical wiring passes through from the contact to the underside of the panel. Your picture is correct.
Shall I expect the same hole in a tray that was used in cars without sunroof?
(I appreciate I will need to disasseeble connector or the contact to run the wire through the hole).
Old 13th February 2014, 09:04 PM
Pretty sure there's space to run it from memory when I did Jim's sunroof.
Old 13th February 2014, 09:06 PM
I believe so - with the panel back just undo the bolts holding the front section in and lift it up. You can do that no problem to have a look-see without disturbing anything else.
I'd say definitely taking the black plug contacts out is the way to route them through they come out easily
Old 14th February 2014, 10:38 AM
texas2201 texas2201 is offline
Ian retro fitted one into my car years Ago - it was a dry but cold day :-)
mine is an early one a 1994
it sometimes sets off the alarm when the fans start extracting - Ian did send me something to fit to see if we could isolate this but it is still in an envelope somewhere
Old 28th May 2014, 01:10 AM
yrk2.7t yrk2.7t is offline
Can you easily replace just sunroof portion from a glass sunroof to a solar one?
Or is it just easier to replace the entire assy?
Old 28th May 2014, 05:12 AM
You need the glass and the 'runners' (and wiring and a relay), but not the whole assembly
Old 28th May 2014, 08:35 AM
If you have a glass sunroof with sliding inside cover you also need to remove that and replace with one designed to slide with the panel only
Old 16th July 2018, 01:29 PM
pajacobs69 pajacobs69 is offline
Default Replace shattered Solar Sunroof panel on Audi A8 1999 FL
Hi I have an Audi A8 4.2 V8 Quattro 1999 FL and I have just noticed that my Solar sunroof has shattered! Can anyone tell me how to remove damaged solar sunroof panel with a replacement one please?
Old 16th July 2018, 02:10 PM
Section 60 Page 110 of this should help -
http://forum.a8parts.co.uk/attachmen...0&d=1420350770
