Limited progress over the past couple of evenings as the cam chain tensioners needed changing which took a while.
Flywheel on - this is a custom lightweight unit from TTV Racing. Its a little over half the weight of the stock one, and a little over half the price! It also takes a nice cheap B5 RS4 clutch. Gearbox going on. This is from a C5 A6 2.5TDI quattro. The ratios look 'plausible' and they're relatively easy to come by. Always the little details ![]() Engine and gearbox bolted together ![]() The manual ECU files which I've obtained from Vera and Goran (thanks both!) have the secondary air injection coded out, which is handy because its pointless and just adds weight and plumbing. Pulled all this rubbish from the engine, and I'll remove the pump from the airbox before it goes back in. Made up some blanking plates for the ports on the back of the heads I pre-modified a spare engine harness, removing all the automatic gearbox and ecu wiring and also the SAI stuff. Still some work to do for the sensors on the manual gearbox - I couldn't do the reverse switch and speed sensor until I had the gearbox attached so I could check the wire lengths so I'll sort that tomorrow. Where I finished tonight: 20 hours. |
Another "What's in the workshop?"
![]() I already learned something. The rear bumper bolt that was seized ![]()
Johannes _________ Audi S8 -99, Pearlescent, Alcantara/silk napa leather, Burr walnut insert, Alcantara roof lining upper pack A8 32V engine ----- Jeep Grand Cherokee -98 |
Proof indeed that higher-intellect aliens have infiltrated our humble human society!
I'm the monster's mother
Someone photoshop that with red hair...……
TDI rear diff:
Original diff in the background Cleaned up the CV joints and replaced the gaskets Installed Sorted the wiring for the reverse switch. New connector and wires to extend the original N75 wires over to the other side of the gearbox Re-used some sleeving from the autobox harness Wrapped up with tape and complete. Ideally I would have liked to sleeve all of this, but that would have meant cutting off the original connectors for the engine mount and speed sender so tape has to do in this case. I may use some split corrugated sleeve on the next swaps. On to the gearbox oil cooler lines. The originals (of which I have a reference set) are no longer available so I cut the autobox cooler lines apart after the engine mount I couldn't get the phone to focus to get a decent pic, but I welded a couple of little pips on the end of each pipe to function as a barb to stop the hoses pushing off. There's no pressure in these, but best to be safe. You can just see the bumps in the hoses. I'll crimp these in place once I'm happy with lengths and routing. Mounted on the engine. They cross under the bellhousing... ...and attach to the gearbox here I'll need to work out some brackets to support the hoses since the originals are hard lines after the engine mount. I'll be able to produce these in advance for the next conversions using spare autobox lines. |
I've been waiting for this!
Was expecting the Grey FE to be the prototype though - that will have to be the 'pre-production' model! What are you doing about the gearbox mounts for the production models? The ones you're using for Bert's look like those "last ones" you got from Audi... Lastly, when are you coming to Australia with one of those kits in your carry-on? ![]()
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
I started off prototyping on the Avus FE, but then Bert's gearbox went pop and he didn't want to spend £3K having it rebuilt only to take it out again once I figured out the swap so we agreed to prototype on his instead. Unfortunately it has taken considerably longer than we expected but hopefully it'll be worth the wait.
Bert's is using the genuine gearbox mounts for simplicity, although I did have to modify the left hand one to clear the shifter. They are pretty simple to copy though so I will redesign them using laser-cut flat plate and make an assembly jig for the pieces so they can be tig welded together. Its likely that's going to come out considerably cheaper than the genuine ones in the end anyway, just like all of the other custom parts. Not sure I'd get away with a propshaft in a ski-bag on a trip to Australia ![]() ![]() |
Hi MJ nice to see you've started shouldn't take you long now! i expect you be 99% finished before the end of the month. keep up the good work
Dave
2002 S8 silver with black half leather 2000 d2 S8 in Racing green pearl, RS4 manual gearbox, 2003 A4 avant TDi 1997 Volvo V40 2.0T 1992 Mazda eunos v spec 1976 Reliant Kitten 1965 Porsche 911 |
Sadly that is unlikely since I've only got tomorrow left on it, then Mike's Murple is in on Monday for a fortnight. I can't believe its Friday already
![]() I finished off the oil cooler lines tonight. This is where they join the original hard lines, now crimped in place. They curve under the bellhousing in roughly the same way as the original hardlines Pump output Return at the back (apologies for the focus ![]() I covered the hoses in adhesive-lined heatshrink to hold them in place and to give them some protection. This should hold its shape even when the lines are hot. If not, I'll consider some more support. New lines top, originals bottom All I managed after this was to put the other engine mount and starter back on and then fill the gearbox with oil. Lots to do tomorrow to get it rolling again so I can push it out of the way to work on Mike's. |
