Old 31st July 2018, 10:45 AM
sarg sarg is offline
The Reg to VIN sites no longer work but I may be able to get the VIN for you if you have a Reg
This was the thread
http://forum.a8parts.co.uk/showthrea...hlight=decoder
Thanks for the link Homer. Given the hundreds of cars I'm looking at, you really don't want me sending you all those reg numbers, hence the search for a self-serve website
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 31st July 2018, 10:46 AM
This was the thread
This tool will give you a VIN from a UK registration for any Audi - not just derv ones
https://www.audi.co.uk/owners-area/e...-your-car.html
Old 31st July 2018, 08:29 PM
homer simpson's Avatar
Send them my way, I'll do as many as I can
I just typed my (private) reg and it didn't work. I then typed my old (original) reg and it worked so may not work if a registration has been changed.
Old 31st July 2018, 11:56 PM
Give this one a try please, 2013 S8:
WAUZZZ4H7DN038543
Probably get crucified for this, but can you get Porsche specs too?
Old 1st August 2018, 09:27 AM
Interesting - I suspect it is based upon an Audi database rather than DVLA then - i.e. if the car has seen a dealer since a plate change then you should be fine!?
Old 1st August 2018, 10:44 AM
WAUZZZ4H7DN038543
Can't do Porsche. This is from an online source - Stick your VIN in here
http://carinfo.kiev.ua/cars/vin/audi
Parameter Value
Brand AUDI
Model AUDI S8 QUATTRO 4.0
VIN WAUZZZ4H7DN038543
Check digit Not used
Sales id 4H2SSA
Production date 2013-07-17
Model year 2013
Engine code CGTA
Engine volume, L 4.00
Number of cylinders 8
Power, KW 382
Power, PS 520
Colour of body L8 (BLACK: phantom black pearl effect)
Colour of roof L8 (BLACK: phantom black pearl effect)
Trim FZ
Gearbox code MEF (8A)
Country of sale 000 ()
Custom options
Parameter Value
E0A Special editions: No special edition
1PD Lockable wheel bolts: Wheel bolts with anti-theft protection (unlockable)
7JW Vehicle class differentiation units/platform components: Vehicle class differentiation 4H0
7MJ Emissions standard: Emission standard EU5 plus
1D0 Trailer hitch: Without trailer hitch
4UF Airbag: Driver's and front passenger air bag with front passenger air bag deactivation
1E0 Activated carbon canister: Without activated charcoal canister
0W2 Label for central electric: Label for central electric English-speaking countries
GS4 Applications: Applications
6XL Exterior mirror setting: Exterior mirrors: with memory function, automatically dimming, electrically foldable/adjustable/heated
EA0 Follow-on warranty: Without subsequent warranty
5SJ Left exterior mirror: Left exterior mirror: convex
6TS Right exterior mirror: Right exterior mirror: aspherical, large viewing field
0K0 Alternative drive system: Without alternative drive module
1X1 Drive layout: Four wheel drive
9WC "Multimedia", video/DVD/notebook connection: Without "Multimedia" in vehicle
A8S Equipment levels: Standard equipment
1KZ Brake type in rear: Disc brakes, rear
J0P Batteries: Battery 580A (105 Ah)
1LX Brake type, front: Disc brakes, front
6FC Components with special surface appearance: Aluminum exterior mirror housings
QF0 Handset (telephone): Without receiver (car phone)
NY0 Battery/alternator capacity: Standard battery/alternator capacity
B0N Component part sets with country-specific design requirements: Component parts set, complying with vehicle type for Great Britain, various parts
1S1 Tool kit and jack: Tool kit and jack
4V1 Front passenger seat control: Front passenger seat adjustment from the rear
0VF Owner's manuals: Information kit in English
9Z0 Operating voltage: Operating voltage 12V
6G0 CD changer/CD player: DVD changer
C12 General operating permit, alterations: Operating permit, alteration
0C0 CO2 variant: Standard
2D0 Cd enhancing underbody panel: Without cd enhancing underbody panel
2MB Shock absorption/suspension, chassis: 4-corner air suspension with electronic shock absorption control
2T5 Double-size standard radio/dual-view display: Without dual-view display
3FA Roof insert/convertible top: Without roof insert (standard roof)
GT4 Decorative strips: Decorative aluminum strips
6F3 Decorative films / emblems: Emblems
3X0 Ski bag: Without load-through provision
0EE Installation differentiation for vehicle components: Installation differentiation for standard transmission
7AL Theft protection system: Anti-theft alarm system, passenger compartment control, backup horn and towing protection
5MK Inserts: Decorative inserts, carbon weave
7M2 Scuff plates: Scuff plates in door apertures with "S" badge
UJ1 Input medium for multimedia: Input medium for multimedia
7X2 Park distance control: Park distance control, front and rear
7W1 Extended safety system: With extended safety system (Pre-Crash Basic)
UF7 Electric interface for external use: Electric interface for external use
GZ2 Power-operated door (power latching): Door power latching
0FA Manufacturing sequence differentiation: Standard manufacturing sequence
8K4 Headlight control: Separate daytime running lights NAR
2V5 Fresh air intake for passenger compartment (with particulate filter): Fresh air intake system with activated charcoal canister
UH2 Parking brake: Parking brake
7G9 Vehicle tracing system: Interface for localization assistant
F0A Vehicle specifications: No special purpose vehicle, standard equipment
9R0 Night vision: Without night vision system
0YZ Weight category rear axle: Without determination of weight category for rear axle
EP1 Noise cancellation: With noise cancellation (ANC Active Noise Cancellation)
0JZ Weight category front axle: Without determination of weight category for front axle
TV7 Base engine: 8-cylinder gasoline engine 4.0 l Unit 079.E
6M1 Tie down straps/net/pocket: Tie down straps
8T1 Cruise control system: Cruise control system (CCS)
VC0 Garage door opener: W/o remote-controlled garage door opener
G1G Transmission specifications: 8-speed automatic transmission for four-wheel drive vehicle
GH2 Rear differential: Rear axle differential Torque Vectoring
6V1 Rear trim panel: Rear trim panel (ECE)
A51 Manufacturer: Audi AG
5N1 Grab handles at roof frame: Folding grab handles
6NN Molding roof liner: Alcantara molded headlining
9AH Heating and air conditioning system: Climatronic with second evaporator and second heating system
8EX Headlamps: LED headlights
FC0 Customized installation: Without customized installation
U1B Instrument clusters: Instrument insert with mph speedometer, clock, tachometer and trip odometer
4L6 Breakaway interior rearview mirror: Breakaway interior rear view mirror, automatically dimming
K8B Body style: Notchback
0M0 Fuel tank capacity: Fuel tank
1W0 Refrigerator: Without refrigerator/glove compartment cooling system
1U0 Folding table: Without table
0Y1 Climatic zones: Standard climatic zones
QR8 Compass/road sign display: Without traffic signs recognition
4D1 Seat ventilation/massage seat: Seat ventilation, front and rear
1Z6 Fuel quantity for initial filling: Increase in initial standard fuel filling
0U0 Fuel quality: Fuel quality 98 RON
1A2 Fuel systems: Fuel system for SI engine with direct injection (FSI)
5C0 Body measures: Without special body measures
KA2 Camera systems/accident sensors: With rear view camera system (type 2)
6W6 Front license plate carrier: Front license plate carrier
5K5 Paint preservative/transit coating: Transit coating film with additional transport protection measures
QQ1 Light package (lighting): With additional lights (interior lighting)
L0R Steering system arrangement: Right-hand drive vehicle
8S9 Reading light: Reading lights, base equipment
1N7 Steering: Dynamic steering
7P3 Lumbar support: Power adjustable lumbar support in front seats and outer rear seats
1XX Steering wheels: Leather trimmed multi-function sports steering wheel w/ Tiptronic
AV0 Driving on the left/on the right: Driving on the left
8RY Speaker installation: Speakers with BOSE sound
2C7 Steering column systems: Safety steering column with electric axial and inclination adjustment
7HC Leather scope: Leather variant 2
8Q9 Headlight range control: With fixed bending light (without headlight range adjustment)
6E3 Center armrest: Front center armrest
FN0 Versions: "S" variant
8Z5 Engine cooling system: Not hot country
DH1 Engine specifications: 8-cylinder SI engine 4.0 l/382 kW biturbo, FSI, homogeneous base engine is TV7
VE0 Vanity mirror in rear: Without vanity mirror, rear
7T6 Navigation device: Navigation system (MID)
GP1 Upgrading measures: Vehicles with special upgrade measures
FQ0 Quattro GmbH: Standard production wheels
AQ0 Quality class: Standard-production quality
CS8 Wheels: Alloy wheels 9J x 20
8YQ Radios: Radio "HIGH"
9JB Smoker's/non-smoker's package: Smoking package, ashtray front and rear
7K6 Direct tire pressure monitoring system: Flat tire indicator
H20 Tires: Tires 265/40 R20 104Y xl
V0A Tire suppliers: Tires w/o specification of tire brand
1G5 Spare wheel/breakdown kit: Space-saving spare wheel, same size (same rolling circumference) as original equipment tires
VG6 Type of tire: Type of tire: design 2
4QF Restraint systems, front: 3-point seat belts front, with electric height adjustment and memory system
PE6 Rear package plus
PS8 Comfort seats with memory function, export
6Q5 Gearshift knob/handle: Sports gearshift knob
A00 Self-collection / special control: No self-collection
2KR Special labels/plates: Labels/plates in English and German
4E7 Lock operation for tailgate/trunk lid: Trunk lid power closing
2K3 Bumper systems: Reinforced bumpers
9P1 Seat belt check: Seat belt reminder, electric contact in buckle
N5D Seat trim covers: Valcona leather seat covering
3PR Seat adjustment: Electric seat adjustment for both front seats with memory system
4A4 Seat heater: Seat heater for front and rear seats separately controlled
0LL Safety certificate: Special plates/stickers/ safety certificates for England
VA2 Cushion/pillow: With two bolsters
7L8 Start-stop system/regenerative braking: Start/stop system with regenerative braking
5XH Sun visors: Sun visors with mirror, illuminated
7Y0 Lane change assist/lane keeping system: Without lane change assistant
VW8 Side and rear windows: Side and rear windows, burglar-restrained
3Y8 Roll-up sun screen for rear and side windows: Electrically operated roll-up sun screen for rear window and for rear side windows
7B3 Socket: 12-volt socket(s)
FA0 Handling production and pre-production: Control of standard production
8X1 Headlamp washer system: Headlight washer system
8N7 Windshield wiper intermittent control/ light/rain sensor: Windshield wiper intermittent control with light/rain sensor
4F2 Door and lid locking system: Central locking system "Keyless Entry"
B09 Type approval countries/countries with special requirements: Type approval Great Britain and Northern Ireland
5D7 Carrier frequency for radio remote control: Carrier frequency 868 MHz without panic button
NT1 Transit coating: Transit coating (type 2)
QV3 TV reception/digital radio reception: Digital radio reception
1VJ Installation parts for engine (engine mount system): Installation parts for eight-cylinder engine
1SA Front underbody guard: Without additional front underbody guard
1EX Identification plates: Special identification plate for EC for M1 passenger vehicle
2Z1 Type sign: Type sign at rear and "Quattro" nameplates respectively
1T3 First aid kit / warning triangle: First aid kit with warning triangle
5Z1 Adjustment of rear seat and backrest: Separate power seats rear
Q2J Front seats: Comfort front seats
9ZW Telephone / telematics: Mobile phone preparation
EW0 Maintenance contract: Without maintenance contract
4GQ Windshield glass type: Windshield in heat-insulating glass
2WA Additional tires (snow tires): Without additional tires
0TD Floor mats: Front and rear floor mats
3B4 Additional child seat anchors: Child seat anchor for child seat system ISOFIX
0RC Ignition/starter switch locking system: Starter switch locking system
9M0 Auxiliary heater: Without auxiliary/parking heater
Old 1st August 2018, 07:13 PM
Joe2.0E Joe2.0E is offline
Great find with the VIN decoder, thanks for posting.
Just discovered our 2006 Q7 was a Launch Edition.👍
Old 18th August 2018, 02:18 PM
Thoughts on these 2 please? I think I think the newer car is better value, but I am attracted to the older car with more spec and exclusive paint but can't decide, head says silver car, heart says black car:
15 plate Exclusive Black (ish) 3.0 TDI Sport Exec
66 plate silver 3.0 TDI Sport
Also been watching this Black Editon that's just been reduced to £30,506, but still think it's a bit high for the mileage:
66 plate 3.0 TDI Black Edition
Old 18th August 2018, 04:27 PM
I thought you wanted an “interesting” daily driver
Of those three, I’d take the high spec all day long
Old 18th August 2018, 04:37 PM
A8s aren’t interesting in your view then?
