And the fight goes on
![]() Did a MMI/Navi update yesterday (had P0022 on the mmi ![]() I later found out that the iginition is supposed to be OFF, which i didn't know when i did the actuall update, i had a 50a supply charger on that i usually use when i update/troubleshoot cars though so the battery voltage never went bellow 12,3v. But apparently that's to low and might be why the updates failed(??) After that i did a test start and quick function check of the car, and all seemed fine so i went forward with the Navi update and that went without a hitch. So did the MMI/Navi activation after that was done. So when all that was done i drove the car home for the night (10.30pm at this point), and i tested the navi on my way home, and it worked ish. Route calculated and all that, gasstations and all those icons came up, but i couldn't see the road itself on the MMI, the voice guidance and dash guidance worked though. So i drove it home and parked the car, without a charger to see what happened. And yeah, it was flat today as well -.-" But ok, with all that said and done! Is it possible / how do it get to update the two devices that craped out on me? Feel like i have to sort that c**p out before i go any farther with the draining problem ![]()
2010 D3 A8L 3.0 TDI QUATTRO BI-Xenon Headlights, Keyless, Bang&Olufsen, DTV, DAB, Rear Camera, BT, TPMS, Soft Close, Auto Boot, AMI, 4 Zone AC, Home Link, All Electric Blinds, Ski Hatch, Black Extended Leather, Seat Memory on Both Sides, Heated / Cooled Sport Front Seats, Electrically Adjustable Rear & Heated Rear Seats Alacantra roofliner, Exterior LED Package, Lane Assist, Adaptive Cruise Control & Heated Steeringwheel ++. Last edited by Exerqtor; 30th November 2018 at 05:55 AM. |
This is going to be a pain to sort out.
The usual culprits are dodgy door handles Faulty alarm module Some part of the mmi keeping the systems awake which i would be inclined to try first as you said the handles all work as they are meant too. If you buy from eBay a most fibre bypass loop you can isolate parts of the most loop with it and unplug that module to narrow down which device is doing it. Or if you are handy with a multi meter you can measure the voltage drop over fuses to find the culprit.
Del ![]() |
Why is battery monitoring/energy monitor ecm not shutting down all ignition circuits when quiescent voltage drops below threshold to ‘save ‘the battery ?
Can you use a shunt inline with battery lead and measure the drain whilst car is asleep , roll boot latch over and wedge the spring loaded press in type switch on boot lid . After say 20 mins see how many amps it’s pulling out , see if amps is a steady draw or doing any cycling or surging . My a8 used to have dickie door handles and would wake up through the night when it was raining, but energy monitor would always clip it and I never had a flat battery on it . I’m wondering if the body module not going to sleep ( gear stick back lighting staying lit ) is a consequence of another draw on a circuit that is not isolated by the energy monitor ecm . |
My car has often been like this after using VCDS. I used to run a scan for 5-10 mins, shut down, lock up and in the morning a flat battery and battery - 10% on display. It seems better if you make sure you close controllers and unplug the interface from the ODBII port before you turn off the ignition.
10% on the display? Have a read of this, it may be relevant:
![]() Since the drain is a s big as it is i hope to be able to meassure it pretty "easy" with the multimeter. I mean it has to be quite a big drain to fully empty a 105Ah AGM battery in under 10 hours :/ Quote:
I've always clicked the boot latch when working on the car and let the trunk stay open, but what does that little press switch do btw? The shift indicator not going black along with the headliner buttons and such's is so damn strange imo, at least without any faultcodes assosiated with it! I have to sort out the MMI updates and make sure all that works first now anyways. Quote:
2010 D3 A8L 3.0 TDI QUATTRO BI-Xenon Headlights, Keyless, Bang&Olufsen, DTV, DAB, Rear Camera, BT, TPMS, Soft Close, Auto Boot, AMI, 4 Zone AC, Home Link, All Electric Blinds, Ski Hatch, Black Extended Leather, Seat Memory on Both Sides, Heated / Cooled Sport Front Seats, Electrically Adjustable Rear & Heated Rear Seats Alacantra roofliner, Exterior LED Package, Lane Assist, Adaptive Cruise Control & Heated Steeringwheel ++. Last edited by Exerqtor; 3rd December 2018 at 05:31 AM. |
The reason the battery goes completely flat is the bem is only capable of shutting down non critical loads, if you study the electrical diagrams you'll see that most devices are wired in a way where they connect directly to the fuse box and if that device doesn't go to sleep or is not controlled by the bem then it's going to continue drawing current.
The lights on the console are a sign that the cars not going to sleep and is constantly sucking the life out of the battery. I have had door handles do it too me, i've seen on the internet things like bad instrument cluster, tv tuner, water in mmi panel, faulty alarm and probably more that can cause this so its just a matter of figuring out whats pulling it down. Have a look at the attachments, give you a place to start.
Del ![]() Last edited by Delboy; 5th December 2018 at 08:57 AM. |
Hmm ok sounds logical, but when you say you've had door handles do that to you. What did you end up doing there? Disasemble the door handle and swap out the switches and coat it up with some conformal coating afterwords? Or swaping out the entire handle? Never had the door panels, let alone the handles of a D3 before so i have no idea how there made lol. Thx for the doc's mate! I hope i get some time this weekend to reflash the MMI and hopefully get that working so that i can go on with the messuring the drain =/
2010 D3 A8L 3.0 TDI QUATTRO BI-Xenon Headlights, Keyless, Bang&Olufsen, DTV, DAB, Rear Camera, BT, TPMS, Soft Close, Auto Boot, AMI, 4 Zone AC, Home Link, All Electric Blinds, Ski Hatch, Black Extended Leather, Seat Memory on Both Sides, Heated / Cooled Sport Front Seats, Electrically Adjustable Rear & Heated Rear Seats Alacantra roofliner, Exterior LED Package, Lane Assist, Adaptive Cruise Control & Heated Steeringwheel ++. |
I just replaced the whole door handle, as I didn't want to go down the route of having the car apart for ages while trying to pull apart the handles.
They are potted and built in a way to stop you from doing that, it's not impossible but time consuming. Actually in the years that I have owned the car I've had to replace all four.
Del ![]() |
Hmm ok sounds reasonable
![]() How did you check yours? Manually check for continuity on the connector pins when pushing the buttons?
