Any idea what could be causing this? 2.8, no loss of coolant or oil. Smokes sometimes, sometimes its absolutely fine.
Looks like water vapour - hot engine on a cold day, with a cold exhaust. Water vapour from combustion condenses in the cold exhaust and comes out as a visible cloud. Its also quite common after a short journey since the condensation sits in the exhaust after the engine is stopped, then blows out on the next start-up. It'll normally go away after the exhaust warms up.
Will be doing major service once winter is over anyways so hopefully that will sort her out ![]() |
Its common for them to make a bit of a cloud on startup if parked nose-down too. Mine does it even with a brand new engine as it usually sits on the ramp in to the workshop.
