Old 22nd December 2018, 09:18 PM
Markiii Markiii is offline
https://forums.quattroworld.com/a8/threads/7344.phtml
suggest the front woofers are only 4" but can take 5.25" with a bit of a trim.
surprisingly small if true
Old 22nd December 2018, 09:23 PM
which would seem to backed up by this
https://www.audiworld.com/forums/a4-...-bose-2888688/
Old 22nd December 2018, 10:02 PM
Yeah 4" is about right. They're pretty small but the ported enclosure makes a big difference. I left the Bose door speakers in place and upgraded everything else.
Old 23rd December 2018, 10:25 AM
thanks Mk, if you've changed the rest could you confirm the sizes?
Old 23rd December 2018, 06:08 PM
Well the front tweeters are exactly the same size as the dome on the Kenwood T-202 - probably about 40mm.
I don't know about the rear deck - those are now tuned ports for the two Infinity 12s using the boot as a 500 litre ported enclosure
I do have a full complement of speakers kicking about. Its just a case of remembering to measure them all
Old 24th December 2018, 08:39 AM
hunker7 hunker7 is offline
10cm in the doors, but I'll personally be fitting 13cm in original enclosures. Deck is 6".
Old 24th December 2018, 09:46 AM
13cm in the original ported enclosures or direct on to the door card? I did think about printing an adapter to allow a larger speaker to be mounted to the door card, but thus far I haven't exceeded the capabilities of the original ported Bose units when backed up by a decent amp and subs.
Old 24th December 2018, 06:09 PM
That's the idea. Speakers I'm getting "should" fit inside the enclosure but time will tell.
Old 9th January 2019, 06:18 PM
13cm speakers in original enclosure
Old 9th January 2019, 06:25 PM
Nicely done Tested them yet?
Have you sealed the back so they use the ported enclosure or are they running 'free air'?
