Old 16th January 2019, 03:54 PM
Default Cleaning oil emulsion from the engine...
Hi all,
I acquired a V8 engine the other day which had popped its oil cooler and mixed oil with the coolant 🤮
If this was still in the car then I'd just run cleaning solution through it a bunch of times until it was clean, but its on a stand in the workshop so I'm pondering the best approach. Obviously all the external pipework will come off, as will the water pump and stat, but the heads will stay on.
I thought I'd canvas you lot for suggestions how to clean it
Go:
ID:	20691   Click image for larger version
ID:	20692   Click image for larger version
Old 16th January 2019, 06:42 PM
Stupid suggestion #1
Would spinning up the water pump with an electric motor or drill work?
(after adding a header tank and connecting the various input/output hoses together of course).
Old 16th January 2019, 08:09 PM
Jet wash connected to one of the inlets?
Old 16th January 2019, 09:24 PM
Funny you mention that - I've actually been pondering mounting a crank pulley in the lathe to spin the water pump via a long belt and pump some water-soluble degreaser round it
Liking that idea too I could put the degreaser in the shampoo bottle...
Oh, and if I make up a plate to go on the back of the heads per the last picture, I can flush each side from back to front exiting via the water pump housing. Hmmm....
Old 16th January 2019, 09:58 PM
27litres's Avatar
27litres 27litres is offline
Water soluble degreaser and a pump. If the water pump is trash, use that - definately agree.
Lathe is a good idea, as you dont want high rpm.
Battery powered impact wrench or strong drill might work too.
Do you get Chemtech CT14 there? Very good product for this job.
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 17th January 2019, 08:37 AM
We don't get CT14, but I do already have some soluble degreaser for the parts washer.
I have a cunning plan forming...
Old 17th January 2019, 09:59 AM
Tjalling Tjalling is offline
Thanks MJ got the same job to do on a 1.8 20vt
A8 d2 W12 swb
Old 17th January 2019, 10:54 AM
Sounds like a contraption from 'The Incredible Machine' game (an old favourite of mine):
You could attach the long belt to a mouse on a wheel instead. Then you just need a gun to fire at one of your cats to trigger the dynamite and get the bowling ball rolling (into the mouse cage)
Old 17th January 2019, 11:06 AM
Love it!
A lathe driving a water pump on a 2m long v-belt is probably going to be terrifying enough though I think
Old 17th January 2019, 11:07 AM
Use scalding hot water as well if you can.
