D2 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor ![]() 1988 E30 Coupe - Royalblau Metallic 2003 S4 Avant - Light Silver Mettalic 2016 S5 Coupe Black Edition - Glacier White |
have finally bought these.......
https://www.nuts4wheels.com/rivera-r...shed-face.html Hopefully they should turn up tomorrow...
current: - newbie to audis, 2001 s8 purchased aug 2018, changes have begun... centre box delete and straight through pipes. - e9 csl 1972, fully restored, silly bits to finish - 2002tii 1972, 'bought by accident' and work in progress - toyota hiace camper, just repainted in gulf racing colours and now getting used - honda c90 custom cub, ' bought by accident'....there seems to be a them here..! (Not so) Recently departed: - very sadly sold to fund the e9....BMW e28 m535 white 1986, owned 12 years, I loved that car. - red mk1 vw golf gti, fully sorted: resprayed, flash red, mk2 1800 16v conversion, uprated brakes, shocks, leather interior, - 1986 Saab 900 turbo convertible sold to get Audi on 'one out, one in' rule imposed by missus...not really adhering to the rule at the moment as can be seen..! |
following above post, can someone tell me what tyre size should I be looking at ?
Use this tyre calculator and play around
https://www.carbibles.com/tire-size-calculator/
I like those wheels
![]() Assuming you’re current tyres are 245/45/18 you have a few options but it depends on if you mind a bit of mild stretch. Personally I’d think about going for a 255/40/19. I,ve got 255/35/20 on 9.5’s and there is a subtle stretch. The calculator indicates your new wheels will sit 13mm closer to the struts....probably ok but worth checking you don’t need a spacer. MJ might know if there’s tonnes of clearance on these or not.
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor ![]() 1988 E30 Coupe - Royalblau Metallic 2003 S4 Avant - Light Silver Mettalic 2016 S5 Coupe Black Edition - Glacier White Last edited by RICKY D; 17th January 2019 at 02:11 PM. |
I don't think there's a spare 13mm, but I'll check in a bit.
245/40-19 is theoretically the correct size but IIRC that size is not very common, and would probably look a bit daft on 9.5s. 255/40 is only 1.5% rolling radius larger so not a big deal, and as Ricky says will give a subtle stretch depending on what tyre brand you go for. There is a significant difference in the carcass width between brands for the same specification so for example Goodyear, Kumho and Pirelli are quite wide fitting so suit a wider wheel whereas Chinesium like Nankang and Accelera are quite narrow and so look a lot more stretched. I'll grab some pics later ![]() |
Thanks all, I am not really looking for a ‘stretch’ look, just want them to ‘sit ‘ right so should I go for 265 or for 255. Sounds like 35 would be a good tyre profile though.
Thoughts ?
Firstly, re suspension clearance, you have plenty of room for the rim:
There's even more at the back. You'll run in to tyre clearance issues with the rear arch liner before the suspension. You definitely would have contact issues with tyres that sit square on 9.5s though so some stretch is going to be inevitable for this to work. 265 is a sort of in-between size which doesn't match the D2 properly. 35 is too small, 40 is too big. 275 35 19 is actually the correct diameter, but that would be really tight in the arches. I think its been done on the rear, but not sure about the front. Theoretically it would fit... But, as I said it totally depends on your tyre choice. 275 Goodyears or Pirellis would be very tight, but Contis or Accelera may be just fine. Here are a few pics to show what I mean. These are all 255/35-R20. Goodyear Eagle F1 Asym 2, on 9". Rubber on the ground 230mm. Goodyear on 9" left, Conti Sport Contact 6 on 8.5" right. Rubber on the ground 190mm!! ![]() Goodyear left, Vredestein Vortrac Ulti on 8.5" right. Rubber on the ground 200mm. Vredestein on the left, Conti on the right, both on 8.5" The Conti would look daft on a 9" rim, but the Vredestein would probably look much the same as the Goodyear. No pic, but I have some Nexen 255 40 19 on 8" rims and they sit the same as the Vredies do on 8.5 so they would be ridiculous on 9s. Given that your wheels are 1" wider than stock, but 13mm closer to the suspension, that puts the tyre in exactly the same place as stock. Personally I would go for something wide in 255 40 19 - Goodyear, Vredestein, Pirelli, Kumho all sit pretty wide. You'll get a bit more stretch, but not silly. If you're feeling brave, something narrow like Conti, Michelin, Accelera, Nexen in 275 35 19. Proportional to the 255s, 275 Contis would probably still be narrower than the Goodyears. Acceleras in that width might actually have more grip than a bicycle tyre ![]() Last edited by MikkiJayne; 22nd January 2019 at 05:02 PM. |
Thanks for this MJ. I didn’t start the original thread but this is very useful to actually see.
The Conti tyre on ground is insane ![]() I’m probably going to change my tyres at some point to a 245/35 as the front coilovers have settled down a bit lower now and I’m starting to hear the odd arch and tyre contact which makes my teeth go funny ![]()
Yeah the Contis are bizarre. For each of the tyres I measured the width of the concrete dust which is picked up when the car rolls in to the workshop. The Contis have about another 10mm of worn rubber on the inner and outer shoulder of the tyre, but it obviously only uses this cornering since there's no dust on it. The Goodyears and Vredesteins have dust right across the worn rubber area. The Contis would be more suited to an 8" rim tbh.
