![]() I hadn't actually done the maths and I was thinking 450KW would probably be enough to charge many cars simultaneously. Still, it should be sufficient to charge a few cars simultaneously at slower charging rates. I don't know what the charging rate of a typical EV is but, if we take a Tesla P100D, for example, which I believe has a 100kWh battery pack, it would take 100kW of energy for one hour to fully recharge it. Assuming a 400 volt battery pack, that's a 'mere' 250 amps! Of course if you want to charge the same battery in 15 minutes (do any EVs charge that fast yet?) that would be 400kW @ 1000 amps! At the other end of the scale, if my maths is correct, you could charge the same battery pack overnight (say 10 hours) using 10kW @ 25 amps, which would theoretically allow simultaneous charging of 45 cars from a 450kW supply.
Mark ------------------------------------------------------ 2002 FE S8 Ebony Black Pearl ------------------------------------------------------ ------------------------------------------------------ Cars Owned: The Tesla Era: 2020 Model S Performance Ludicrous+ (present) (Black, with all black premium interior and carbon fibre décor, 21" sonic carbon twin turbine wheels and FSD capability) The Audi Era: '97 A8 4.2 (Ming Blue) --> '96 A8 4.2 QS (Dark Green) --> '02 FE S8 (present) The Citroen Era: '84 BX 1.6 RS --> '89 BX 1.9 DTR Turbo --> '94 XM 2.0L Turbo --> '96 XM 2.0L Turbo Exclusive --> '00 Xantia Activa 2.0L Turbo The Banger Era: '76 1.2L Lada VAZ-2101 (Ruski Fiat 124) --> '80 1.7L Morris Ital HL, finished in Ermine White and Rust Last edited by moltuae; 12th February 2019 at 04:55 PM. |
