Old 22nd February 2019, 08:14 AM
Same problem here, I posted about it not long ago IIRC.
Let us know if Sugru works OK.
Old 22nd February 2019, 12:41 PM
27litres's Avatar
27litres 27litres is offline
Sugru sounds like a good idea. Easier to form than silicone.
What's the adhesive quality like? As to do an effective repair will really need to stick to the lights.
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 22nd February 2019, 12:59 PM
johnny_quattro's Avatar
It seems to have stuck quite well in the boot lid area and requires 24 hours to cure/go solid. There's a certain amount of give/springiness if you press it hard enough so I'm fairly sure it will do a good job with that annoying flapping bit on my headlight surround. Still, the proof of the pudding is always in the eating so let me have a go at it first beforehand.... I will probably have a crack at this next week sometime as I'm due to leave shortly for Somerset. Hopefully I might get spotted on my way down to the South West of England.
Old 25th February 2019, 07:03 PM
Default Had a go
I've had a go at repairing the NSF headlight surround. Compared to the offside headlight, it was broken right at the join between bonnet shutline and front wing and the remaining material was pretty frail. I shaped and formed the Sugru black stuff whilst supporting it as best I could from behind ( or you'll have nothing to push against).
I admit that the repair is not fit for showroom quality but it works for me. It was annoying to see that little flap of rubber poking out - I pushed it back in on a regular basis but the constant flow of air ensured that it worked its way loose each time after a couple of days. Now it's fixed.
Whilst working on the repair, I double-checked my handiwork on the boot grommets that I've also recently repaired with black Sugru and it all looks good.
