Old 23rd February 2019, 09:33 PM
D2s which had factory 20" wheels have steel struts with larger wheel bearings whereas the non-20" FL cars have alloy struts. The ABS sensor for the steel strut is unique and genuine only so heinously expensive.
Old 24th February 2019, 08:45 AM
Markiii Markiii is offline
By strut do you mean hub?
Old 24th February 2019, 09:10 AM
If you like yes. I call the bit that the control arms bolt to the strut or upright, and the turny bit the hub, but they are generally interchangeable Technically upright is probably more correct since its double wishbone rather than macpherson strut.
Old 24th February 2019, 09:12 AM
Nognar Nognar is offline
It was being replaced as it had failed, thrown a code and was no longer sending a speed reading.
Old 24th February 2019, 10:06 AM
Yes upright, that's what I meant. We got there eventually
Must check what mine are
Old 24th February 2019, 02:11 PM
So there's obviously a reason for this, but what is it and what are the downsides of fitting FE 20" wheels to a car with non-FE alloy suspension?
Or were they just using up the stock of some suspension variant made maybe for the armoured vehicle or some other rare special option?
Old 24th February 2019, 02:57 PM
I honestly don't know. It is totally counter-productive to handling and ride comfort to fit heavy 20" wheels and then to couple them with even heavier steel uprights which weigh 5Kg more each than the alloy ones. They were specially produced for the 20" cars rather than something which needed using up and are available in both Brembo and HP2 brake fitment.
I can only surmise that something in the load calculations suggested that the alloy upright would not take the stresses of the 20" wheel (or for that matter the 3.3 V8 TDI) and so they designed new uprights from steel instead, and put the larger 92mm bearing in them.
The lower arms are also different for the steel struts - the lower rear has a different inner bush. Possibly stronger?
People have been running 20" wheels with alloy uprights for many years and they are absolutely fine. Whatever calculation it was, there is clearly a substantial safety margin in the alloy stuff. Its probably an extreme use case which no one will ever actually encounter.
