Old 29th March 2019, 06:44 PM
hunker7 hunker7 is offline
That is the exact symptoms of when I had a master cylinder fail due to the scenario I described. One circuit (ie one half of the master cylinder) failed so I had no brakes on FR and RL (or vice versa) and then once the pedal had almost reached the end of its travel, it braked on the other two wheels.
The brake fluid reservoir will take 2 bar if its not cracked or damaged. It'll expand quite alarmingly, but I haven't had a D2 one pop yet! You'll not push fluid through the ABS pump at 10psi.
I really hope it's not the master.
OK I'll take the risk and go to 30psi tomorrow. Should I have all 4 calipers open or?
