Old 31st March 2019, 08:44 PM
I've had this on my D2. I think some people just rip off these panels, and then find out afterwards how they're attached.
The perpetrator of this mess actually stuck the broken part to the back of the panel with masking tape for someone else to fix later
Next job - find out why the ECU won't communicate with VCDS. No continuity between the body harness and ecu connector...
Well, there's your problem! I unwrapped the engine harness and this wire just broke when I touched it.
Look at the bulges in the insulation! This wire, somehow, has corroded from the inside out. These bulges are all along its length apart from an inch at either end, so the water hasn't got in from the ends. It's been absorbed through the PVC jacket, but only this wire! All the others are perfectly fine
Cut out the bad wire and spliced in a new piece
Comms re-established, I wrapped the harness up again and put it all back to bed
ID:	21049   Click image for larger version
ID:	21050   Click image for larger version
ID:	21051   Click image for larger version
ID:	21052   Click image for larger version
ID:	21054   Click image for larger version
ID:	21055   Click image for larger version
ID:	21056   Click image for larger version
ID:	21057   Click image for larger version
Old 31st March 2019, 09:11 PM
RS6's Avatar
RS6 RS6 is offline
Good grief thats in a state loads of problems there!
Excellent work
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 31st March 2019, 09:27 PM
Well done Doctor
Good fix
Old 31st March 2019, 09:38 PM
RICKY D's Avatar
RICKY D RICKY D is offline
I’m in awe of your work MJ.
Another great thread
Old 1st April 2019, 12:07 AM
H-M3 H-M3 is offline
Someone knows their SH##! Sorry that’s the only way I could express.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 1st April 2019, 06:35 AM
Spanker's Avatar
Spanker Spanker is offline
We all love these posts.
Not all of us may comment but we all love them. Especially when our own cars have been in this situation.
Dean
Old 1st April 2019, 09:03 PM
On to the tensioner pads. Front end off and locking tools in.
Removed the coil packs and wiring harness to get access to the cam covers
Started on the passenger side
Whenever I'm working on an engine with the belt off I cable-tie the locking bar to the cams so they can't move. The passenger side has a habit of jumping round 15 degrees when you're not watching!
Spotless inside This engine has been dealer-serviced to this point and fed almost exclusively on V-power or Momentum fuel and it obviously likes it. I've never seen an engine this clean inside (apart from my brand new one).
Still an oily mess on the outside though
New pads in place
Ready for the cover to go back on with a new gasket
That side done
Even in a spotless engine, the pads are still worn - the #1 cause of premature engine failure in D2s. Shown above the pad, the #2 cause - the hydraulic belt tensioner.
ID:	21101   Click image for larger version
ID:	21102   Click image for larger version
ID:	21103   Click image for larger version
ID:	21104   Click image for larger version
ID:	21105   Click image for larger version
ID:	21106   Click image for larger version
ID:	21107   Click image for larger version
ID:	21108   Click image for larger version
ID:	21109   Click image for larger version
Old 6th March 2022, 10:51 AM
I am having the said same issue with my VCDS Lite. Actually with my cheapo reader as well. The cheapo says linking error, VCDS unable to connect. Did you go direct to the ECU or are there prior items to check? I have checked the terminals at the OBD2 port and all seems good, used a breakout box and the resistance between terminals also seems to check out.
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 6th March 2022, 07:07 PM
I checked continuity between the OBDII port and the ecu box connector, which was fine, and then from the ecu box connector to the ecu itself, which wasn't.
Do you have wiring diagrams? I know the diag pin on the ecu is #43 but I can't remember which plug it's on in the ecu box.
Old 6th March 2022, 09:45 PM
Thanks MJ.
I think I have diagrams, just need a quick refresh. Will go digging next week.
Paul
Gosport UK
Honda Jazz
