Old 1st April 2019, 09:16 PM
Those of you of a nervous disposition might want to skip ahead a bit here so here's a picture of some ridiculously cute bunnies:
Are you still here? Are you really sure???
Here's Lisbeth and Gizmo while you prepare yourself....
Ok, don't say I didn't warn you......
This is the driver's side tensioner as it came out
Holy ****!!! The pad broke in half on the drive here The engine literally had minutes to live! I removed the tensioner and the pad stayed in the engine, broken in half sitting on the chain. One more cold start and it would have spat out the pieces of the pad and valves would have met pistons.
I had to go and have some cake after I found this. I forgot to take any more photos.
Talk about dodging a bullet.
ID:	21112   Click image for larger version
ID:	21113   Click image for larger version
ID:	21114   Click image for larger version
Old 2nd April 2019, 09:26 AM
Thanks goodness for the bunnies, cats and cake! That was a near miss for Stephen. I wonder what mine will be like?
Old 2nd April 2019, 03:24 PM
gninnam gninnam is offline
So close
MJ - wife wants to knnow the breed of the cats (not interested in the near engine fatality...)?
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 2nd April 2019, 03:39 PM
They are Maine Coons They're about a year old in the pic. They are both considerably larger now!
Old 2nd April 2019, 06:20 PM
I want another Maine Coon - loved mine (30th birthday present!) - this time we should have two
Great swerve on the engine destruction stakes!
Old 2nd April 2019, 10:18 PM
Just for information, here's a genuine Audi timing belt hydraulic tensioner next to an INA one. They clearly came out of the same mould, but the INA one is missing the Audi logo and part number:
The water ways are similarly as spotless as the internals
New pump and thermostat and all new original bolts. The old bolts have the familiar green zinc coating (well, most of them are rusty by now), but new ones are black. This is a new coating which mixes better with aluminium and lasts longer.
A familiar mess down at the crank sprocket
That's better
This bushing thing has to come out - its just a sliding fit so a couple of magnetic pick-up sticks can encourage it out
With the oil seal removed the oil pump chain is visible. The sprocket for this is actually driven by friction from the bushing which is held in by the crank sprocket.
New oil seal in
Bushing back in and sprocket back on with a new bolt. The torque on this bolt is immense - 240Nm then 180°
Belt all done
ID:	21136   Click image for larger version
ID:	21137   Click image for larger version
ID:	21138   Click image for larger version
ID:	21139   Click image for larger version
ID:	21140   Click image for larger version
ID:	21141   Click image for larger version
ID:	21142   Click image for larger version
ID:	21143   Click image for larger version
ID:	21144   Click image for larger version
ID:	21146   Click image for larger version
Old 4th April 2019, 07:58 AM
Epic!
Old 4th April 2019, 08:51 PM
The bung on the front of the inlet manifold tends to perish and fall off leaving a big vacuum leak. This is an enterprising solution, but not good enough
Better
Nicht gerfingerpoken rusty oil sumps Obviously I poked this after refilling the oil, but I guess this is the best place for it to spring a leak. Sumps are still available new, but on back order so A8parts supplied a replacement next-day
Engine all buttoned up
Nice and clean now
On to the Milltek. This was originally a facelift system which had been modified to fit a pre-facelift. I had to modify it back again!
A couple of pieces of 60mm stainless tube tacked in place. This was actually several hours of fiddling and fettling which included adjusting the gearbox mounts to get the downpipes to line up!
Tig welded
All hooked up. Note no H-pipe. This was lost when it was originally modified and we decided to leave it out to see what it sounds like. Pretty damn epic actually
ID:	21174   Click image for larger version
ID:	21175   Click image for larger version
ID:	21176   Click image for larger version
ID:	21177   Click image for larger version
ID:	21178   Click image for larger version
ID:	21179   Click image for larger version
ID:	21180   Click image for larger version
ID:	21181   Click image for larger version
ID:	21182   Click image for larger version
ID:	21184   Click image for larger version
ID:	21185   Click image for larger version
Old 5th April 2019, 02:43 PM
Nognar Nognar is offline
Looks at thread...
….looks at Bank Account...
Old 5th April 2019, 02:45 PM
Originally Posted by Nognar View Post
Looks at thread...
+1
